Compression Ratio! which one is right?
Old Nov 24, 2005 | 08:47 AM
00situner's Avatar
Default Compression Ratio! which one is right?
Ok i am building a d16z6 and i thinking about srp pistons and tuner toys rods.
I would like to know what kind of compression ration everyone is running and what is the best for about 350 horse power?
Old Nov 24, 2005 | 09:04 AM
whoneedzvtec's Avatar
Default Re: Compression Ratio! which one is right? (00situner)
i would have to say the most common is 9:1. me personnaly, i use 8.5:1. but my car is'nt an all out race car, just wanted to be a little safe thats all, good luck.
Old Nov 24, 2005 | 10:57 AM
platinum00's Avatar
i used to run 8.5.1 SRP's, when i sleeved the block i went to CP 9.1
i think 9.1 is bit better for the street....
platinum.
Old Nov 24, 2005 | 11:01 AM
s2kdre's Avatar
Default Re: Compression Ratio! which one is right? (platinum00)
i seen a dyno sheet of 10.1 and 9.1 with the same motor and turbo and there is no power difference or spool times at all.
Old Nov 25, 2005 | 07:54 PM
Default Re: Compression Ratio! which one is right? (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">i seen a dyno sheet of 10.1 and 9.1 with the same motor and turbo and there is no power difference or spool times at all.</TD></TR></TABLE>
im not saying u r lying or anything, and i may be wrong but that does'nt sound accurate. if this is true, than what gains would there be by raising comp. why not everybody stay 8.0:1 and be safe and run a ton of boost? if i am wrong about this please let me know though. i would like to know the real pros and cons to having raised and lowered comp. if i aint correct.
Old Nov 26, 2005 | 04:42 AM
00situner's Avatar
Default Re: Compression Ratio! which one is right? (whoneedzvtec)
I thought the same thing but thanks guys for the info keep it coming!!
boostfever
47
Oct 25, 2010 09:59 PM
dohcMONSTER
12
Apr 1, 2006 08:24 AM
Dmc1
15
Feb 6, 2006 11:06 PM
92 civic VX B18c
Dec 26, 2005 07:50 AM
d16z6Tcrx
Sep 25, 2005 09:40 AM
