SOHC ninjas - who's running a .040" (or 76mm) overbore on stock sleeves?
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I've read a lot of stock sleeve SOHC buildup threads where people are using 75.5mm pistons, just like DOHC guys are using 81.5mm pistons.
Anyone here running a 76mm (or 82mm) stock sleeve setup with forged internals? I am interested in running the Vitara pistons, but the block I have does not allow me to run stock bore because the cylinders are out of round. The next size up is .040" overbore, which is 76mm.
I think USDM 4G VTEC is running 76mm pistons, anyone else?
1 Post
Re: SOHC ninjas - who's running a .040" (or 76mm) overbore on stock sleeves? (boostincoupe)
i have a bare block that you could have... it has low miles, walls seem pretty smooth.
Re: SOHC ninjas - who's running a .040" (kabaroo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo »</TD></TR><TR><TD CLASS="quote">i have a bare block that you could have... it has low miles, walls seem pretty smooth. </TD></TR></TABLE>
I already have a Y8 block, but thanks.
Isn't that block fucked due to a spun rod bearing?
Re: SOHC ninjas - who's running a .040" (boostincoupe)
http://www.sohchonda.com/v-web...=8550
He is!!!!! Look Here!!!!! Lookie!!!!!!!!
Re: SOHC ninjas - who's running a .040" (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">http://www.sohchonda.com/v-web...=8550
He is!!!!! Look Here!!!!! Lookie!!!!!!!!</TD></TR></TABLE>
So I read.
Hopefully he'll get some numbers up so we can see what numbers it pulls.
So I read.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">
Isn't that block fucked due to a spun rod bearing? </TD></TR></TABLE>
umm, the girdle is messed up. the BARE block seems ok. IDK i was just trying to help, its free btw! dont give me that crook face! ill ICE you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo »</TD></TR><TR><TD CLASS="quote">umm, the girdle is messed up. the BARE block seems ok. IDK i was just trying to help, its free btw! dont give me that crook face! ill ICE you.
Have a
Have a
1 Post
Have a </TD></TR></TABLE>
Done... can we be friends now?
Enough with the chit-chat, back to tech. Why do you wanna run a larger bore?
Re: SOHC ninjas - who's running a .040" (elcangripapi)
I did a GSR 82mm bore stock sleeves with forged pistons and it has been running strong for several months now with no problems and we did a y8 block .40 over stock sleeves running strong as well.
boostincoupe
08-30-2006 10:04 AM
