B18B1 stock bottom end with p30's and 125 shot ???
my current set up consists of a b18b1 block with p30's on stock rod bolts and head studs....so my question is with proper tunning can i be reliable with a 125 shot ?? i dont plan on reving past 6500 rpm...
any insight or similiar set up and input would be greatly appreciated......
yes... if done properly.. it will hold.. i rev my LS to 7 grand so i fall higher in the powerband after the shift... just make sure you dont hit a rev limiter while on juice..
well i want to hit it with as much nitrous as safely possible which is essentially impossible with nitrous....would it be better with its stock ls pistons in place ?? cause i have another ls block sitting...
Re: (JDMisGOOD)
Block guards are junk. I'd replace rod bolts before headstuds. But it doesn't hurt to run head studs. fuel system upgrades. run a good engine management,fuel pump,and some bigger injectors.
are we talking larger as in using Prelude injectors or as in using dsm 450's and an s-afc ?? i figured head stud because i thought headgasket leak may become an issue when the motor is under nitrous....
woah umm thats a little out of my budget .....are u sure the dsm 450's and s-afc wont work ??? or perhaps a custom tuned chip i ca npurchase off some one with a similiar setup ??
Re: (The Stance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Stance »</TD></TR><TR><TD CLASS="quote">woah umm thats a little out of my budget .....are u sure the dsm 450's and s-afc wont work ??? or perhaps a custom tuned chip i ca npurchase off some one with a similiar setup ??</TD></TR></TABLE>
That would work... Not ideal by any means. but yes it would work.
