Compression ??...but different than the rest....LS VTEC
Old Nov 23, 2005 | 05:16 PM
m R g S r's Avatar
Default Compression ??...but different than the rest....LS VTEC
I assembled an ls vtec motor...the bottom end came from an automatic ls...prob a decent amount of miles.
Reason i mentioned automatic is because obviously the car couldn't have been modded like crazy due to automatic limitations. And it prob wasn't revved like crazy either.
anyway...
after assembly and spendin a shitload on the right parts (oem timing belt, water/oil pumps, ls HG, GE ls/vtec conversion kit etc...) i tried a compression test BY HAND. I never put the motor in the car. Anyway...cranking by hand (fast through the compression stroke) i got 150 150 150 125. now i KNOW if i throw on the tranny and starter it will prob bring those numbers up. So i threw some oil in the low cylinder...it then shot up to 150....okay...then i threw some oil in the others...went up to about 170-180
Butt the tranny is still in the car.. . . . . . so i didnt do the right test yet, and the motor is cold, prob not ran for a year or so.
i cleaned the **** outta the block before i assembled it. removed all the carbon buildup....and the hone on the cylinders looks perfect. no scarring AT ALL!!
so my ??
should i bother throwing the motor in the car? i am going to use my old turbo setup (gt32e, 3" turbo back, precision 750hp ic, etc) to go for about 320-350whp....
think its worth it to even throw this bitch in, or am i waisting my time?
Old Nov 23, 2005 | 05:38 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Compression ??...but different than the rest....LS VTEC (m R g S r)
I kinda don't get what you said to begin with, did you dissasembel the whole block and hone it or did you just put new oil pump and other parts on it?
Wait never mind I didn't read the thread right.. haha
I wouldn't even bother putting it in, do a hone on it first and replace the rings.. than give it a try, might as well do it now sence its already out..
Old Nov 23, 2005 | 06:36 PM
m R g S r's Avatar
Default Re: Compression ??...but different than the rest....LS VTEC (Adi Radoncic)
naw no way im replacing stock rings.....if it really is that shot im doing pistons/rods/stock sleeves.....
the hone looks good...its from the factory....
Old Nov 23, 2005 | 06:44 PM
Boosted2K's Avatar
why not use that sexy benson motor in the back?
Old Nov 23, 2005 | 06:47 PM
m R g S r's Avatar
Default Re: Compression ??...but different than the rest....LS VTEC (Boosted2K)
i need the $$
and it was an unrealistic goal i set
in order to take advantage of the block i would have had to spent another $5-7k in parts(twin disk, sumped tank, external pump/lines, fully built head, new turbo setup, and a longgg *** wait for jeff evans to tune it...not to mention finding a way to trailer it down to him.......and i have absolutely no $$ right now....
soo yea...im keepin this setup simple and cheap
Old Nov 23, 2005 | 07:03 PM
cubish's Avatar
why not just buy some je rings for like $100?
Old Nov 23, 2005 | 07:06 PM
eg crunkmonster's Avatar
Default Re: Compression ??...but different than the rest....LS VTEC (cubish)
ummm doesnt ur motor have to be warm for a compression test
Old Nov 23, 2005 | 07:10 PM
On Fire!
Default Re: Compression ??...but different than the rest....LS VTEC (eg crunkmonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg crunkmonster &raquo;</TD></TR><TR><TD CLASS="quote">ummm doesnt ur motor have to be warm for a compression test</TD></TR></TABLE>
Not necessarily, as long as the numbers coming out are consistent the motor can be cold while checking for compression.
If your trying to keep it cheap replacing the rings and honing it would be the answer for ya, but if not just get some pistons and rods, polish up the crank, some bearings, hone the block and u got it all done. But again I thought you were going for cheap?
Old Nov 23, 2005 | 07:31 PM
xenocron's Avatar
Going with a different setup i see
I'd throw it in and see...but thats just me
Old Nov 23, 2005 | 07:49 PM
m R g S r's Avatar
Default Re: Compression ??...but different than the rest....LS VTEC (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">Going with a different setup i see
I'd throw it in and see...but thats just me </TD></TR></TABLE>
my conclusion
I am throwing it in. if it works it works. if not...it just wont make the power i want..but she will run for a lil. pistons and rods are in the future anyway...i have cheetah building me a motor right now anyway
so inn she goes tomorrow...and chris can have fun tuning it lol
Old Nov 23, 2005 | 08:17 PM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">...and chris can have fun tuning it lol </TD></TR></TABLE>
Cant wait
Vtecme92
Apr 14, 2006 07:16 AM
turbo_b16_ex
Jun 28, 2005 06:58 PM
300guy
Jun 28, 2005 10:57 AM
dwn4cause
Dec 22, 2004 07:58 AM
b16vtecsol
Nov 1, 2004 07:48 PM
