why are 2 38mm wastegates so uncommon????
they are cheap/ abundant and 76mm when comboned.........
why are people opting for hks 50-60mm or even turbosmart or greddy monster sized wastegates????
enlighten me please
enlighten me please
Re: why are 2 38mm wastegates so uncommon???? (miamidamian)
cus its more jdm!
And i bet when you start doing some math a 50mm gate would have more usable space than two smaller ones also easier to control most likely? I'm not sure.
But at the same time i'm seriously considering putting my two 35mm tial knockoffs on my ram-horn i built. I've been running one 35mm off of the wastegate hole on the turbine housing with limited success and i have two so why not; if it doesn't work i'll rethink it
2 38mm=9068.32mm^2
1 HKS 60mm=11304mm^2
and just for reference a 76 mm gate=18136.64mm^2
thats why, area is a square function, it isn't direct addition, beyond that why plumb in an extra gate unless boost creep is a problem
Re: why are 2 38mm wastegates so uncommon???? (Twisted Greed)
2 38mm gates is still gonna save you more money then buying a hks or turbonetics 50mm. and will work better than 1 38... i was thinking about putting another tial 40mm on my car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twisted Greed »</TD></TR><TR><TD CLASS="quote">2 38mm=9068.32mm^2
thats why, area is a square function, it isn't direct addition, beyond that why plumb in an extra gate unless boost creep is a problem</TD></TR></TABLE>
you dont use the entire surface area of the valve to loose exhaust gasses; a lot of the valve is shorouded
I'd take 1 big gate over 2 smaller ones any day. Twice the chance of failure with 2 of them. Diaphams could tear/leak, valves stick, lines come loose, etc. Plus, with 1 HKS GT gate, you're getting a much better quality piece than a tial 38.
Re: (Zakar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar »</TD></TR><TR><TD CLASS="quote">what about those Sweet 50mm XS power WG's? there like 150 bucks</TD></TR></TABLE>
cuz they're low quality... the price is sweet. but the product licks ***** i woudlnt trust the POS to run my 400+ WHP car
Re: (Zakar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar »</TD></TR><TR><TD CLASS="quote">i heard the intercoolers and WG were the only good products they made.. it looks EXACTLY like the HKS unit</TD></TR></TABLE>
Like everything else in the world...looks can be deceiving
Re: why are 2 38mm wastegates so uncommon???? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">I'd take 1 big gate over 2 smaller ones any day. Twice the chance of failure with 2 of them. Diaphams could tear/leak, valves stick, lines come loose, etc. Plus, with 1 HKS GT gate, you're getting a much better quality piece than a tial 38. </TD></TR></TABLE>
i think some would argue the opposite; half the chance of failure; if one gate dies the other opens
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">
cuz they're low quality... the price is sweet. but the product licks ***** i woudlnt trust the POS to run my 400+ WHP car</TD></TR></TABLE>
electronic boost cut; use it love it
Re: (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc »</TD></TR><TR><TD CLASS="quote">Like everything else in the world...looks can be deceiving </TD></TR></TABLE>
but in this case, they arne't
the SSAC wastegates are very nice pieces. have had more tials fail than them in my expierence. most ppl say to take them apart and check all the bolts...but, i've only had one with a loose BOLT (no s on that) and it was on the outside, so no big deal even if i hadn't checked
i'll be running one of hte 60's on my next setup, just to see if they fall in line wiht the smaller gates in quality
Better quality than Tial? Hmm... I know HKS parts are nice, but I don't think its accurate to say "better" quality than Tial...
maybe you just mean the Tial 38mm gates, the valve is "not intended for use w/ race gas"
Re: (project dc2)
Have you run one?
Have you run one?
Re: why are 2 38mm wastegates so uncommon???? (Hondaddict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaddict »</TD></TR><TR><TD CLASS="quote">Better quality than Tial? Hmm... I know HKS parts are nice, but I don't think its accurate to say "better" quality than Tial...
Have you seen and worked with the new HKS GT gate? It's by far the best quality wastegate i've ever seen. I think the fact that the 38mm valve is not intended for use with race gas is significant in there being a quality difference between the two. Do you not?
Have you seen and worked with the new HKS GT gate? It's by far the best quality wastegate i've ever seen. I think the fact that the 38mm valve is not intended for use with race gas is significant in there being a quality difference between the two. Do you not?</TD></TR></TABLE>
hes right the tial screws up on race gas...the turbo smarts and hks dont
Re: why are 2 38mm wastegates so uncommon???? (D@nnY)
I thought you could swap out valves for use with race gas?
EDIT: just checked and it looks like they do have different valves for leaded/unleaded.
http://www.tialsport.com/prod_wg_38.htm
Re: why are 2 38mm wastegates so uncommon???? (Pay2play killa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pay2play killa »</TD></TR><TR><TD CLASS="quote">
If both wastegates are necessary to control boost safely, then even if one unit fails, the boost will creep regardless.
Re: why are 2 38mm wastegates so uncommon???? (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger »</TD></TR><TR><TD CLASS="quote">
If both wastegates are necessary to control boost safely, then even if one unit fails, the boost will creep regardless.</TD></TR></TABLE>
****, you will instantly have twice as much boost, if one of the gates wasnt opening.
Re: why are 2 38mm wastegates so uncommon???? (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic »</TD></TR><TR><TD CLASS="quote">
****, you will instantly have twice as much boost, if one of the gates wasnt opening.</TD></TR></TABLE>
if you have 2 wastegates that open at 10 psi and only one opens you still will have 10 psi
its not like you would have one with a5 psi spring and another witha 5 psi spring and you would get 10 psi...think about it
I've ran a Tial 40mm gate for 4 years. It's seen plenty of leaded fuel past it and I've never had an issue. It will hold .9 bar spring pressure on a T67 no problem, and it held 32 PSI on a GT2871R.
I've never messed with the HKS gate because of the cost and the fact my Tial has never let me down.
Re: (99_GS-T)
i have the race valve on my wg, it really wasn't that much different in terms of price. Its just that it has to be ordered rather than shipping instantly if the place as it in stock.
Re: (seen4ever)
If you want to compair usable surface area, it's the not bottom surface of the valve. Air can't pass through a valve - it moves past it's perimeter. You take the circumference multiplied by maximum lift. Thats the benifit you get from larger valves in a head - for the same lift, it has more area around the lip for the air to pass.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">
its not like you would have one with a5 psi spring and another witha 5 psi spring and you would get 10 psi...think about it </TD></TR></TABLE>
not if your turbo outflows one of the two specified gates.
