Those of you using HKS mani on a B engine..........
Old Nov 21, 2005 | 03:17 PM
NCchris's Avatar
Default Those of you using HKS mani on a B engine..........
how in the hell did you get an air cleaner on the turbo intake without grinding away part of the block including the serial number?
TIA
chris
Old Nov 22, 2005 | 06:00 AM
b20turboic's Avatar
Default Re: Those of you using HKS mani on a B engine.......... (NCchris)
my buddy used the hks a long time ago ... use a screen
Old Nov 22, 2005 | 10:59 AM
Tony the Tiger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCchris &raquo;</TD></TR><TR><TD CLASS="quote">how in the hell did you get an air cleaner on the turbo intake without grinding away part of the block including the serial number?
TIA
chris</TD></TR></TABLE>
Same here, I am using a mesh screen. There is no way you could place a filter there unless you are running a super tiny turbo and a 2" inlet. I barely had enough room to fit a hose clamp there (with the GT2871R).
Old Nov 22, 2005 | 11:14 AM
NCchris's Avatar
Default Re: Those of you using HKS mani on a B engine.......... (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">
Same here, I am using a mesh screen. There is no way you could place a filter there unless you are running a super tiny turbo and a 2" inlet. I barely had enough room to fit a hose clamp there (with the GT2871R).</TD></TR></TABLE>
Thanks,
I'm using a Nissan T28, inlet is 2-1/2". I was thinking about a combination of 90° elbo's to allow filtered air into the intake. So far, I haven't been able to find bends close enough. Wonder what HKS supplied with their kit?
Old Nov 23, 2005 | 07:11 AM
b20turboic's Avatar
did you look into aluminum bends ??? say from ATP i believe .... very tight bends, they use them for making new turbo outlets (IE.. Different angles / bends). I used one off of my outlet and made my intercooler a backdoor to reduce piping. Id say thats the tightest bends you can find unless you pie cut a steel pipe but thats a lot of welding.
Old Nov 23, 2005 | 08:46 AM
Dr Pooface's Avatar
Default Re: Those of you using HKS mani on a B engine.......... (b20turboic)
My compressor's on the drivers side, lots of room for a filter there.
ICeDoUt
24
Apr 6, 2006 09:48 AM
89crxsleeper
Nov 26, 2005 08:19 PM
BrokenRex
Sep 13, 2005 10:23 AM
StolenTeg
Jul 26, 2004 08:00 AM
Tinker219
Apr 23, 2003 01:22 PM
