Budget turbo for F22?
I've tried searching for F22 turbo and what not in here but I'm not getting much of an answer. Here's my question...
I'm looking to turbo my F22 (I'll also do being a tranny swap as I have an auto... as, from what I understand, turbo+AT=baaaaad)
Because I'm doing a tranny swap and I'm not made out of $$ and am in the process of switching jobs, I'm trying to figure out a turbo setup that'll give me the best bang for the buck... can anyone help me figure out a setup for this?
Thank you!
Thank you!
Re: Budget turbo for F22? (chiefyaccord)
budget turbo = nitrous.
i say if you are going to boost, to do it right. it is not cheap, but its damn good fun.
but nitrous will satisfy your craving for a bit. plus you wont have to really do much to the fuel/ems side of things this way. just buy a kit and go manual. pm me if you really want to boost your f series and ill see if i can help out at all.
Which would you suggestion? Nitrous Express or what? And how often can you use it before having to get more?
I'm not that knowledgable with boost, but tryin to learn...
Re: Budget turbo for F22? (f22b2tdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22b2tdave »</TD></TR><TR><TD CLASS="quote">budget turbo = nitrous. </TD></TR></TABLE>
Save that for the neons and mustangs.
Re: Budget turbo for F22? (fizix)
to do a budget build get an eclipse-talon exhuast turbo manifold and turbo it will all bolt up all you have to do is redrill 3 holes! search on homemadeturbo.com i did a bit about about the same thing and there was a few threads on it. If you could find one at a junkyard or something you could just take the mani,turbo,dp,injectors,blow off valve and resister box and side mount intercooler thats almost a hole kit but yeah do a search and you will see alot of ppl use the eclipse turbo manifold on there f22-h23 engines!
Re: Budget turbo for F22? (lshatch1.8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshatch1.8 »</TD></TR><TR><TD CLASS="quote">to do a budget build get an eclipse-talon exhuast turbo manifold and turbo it will all bolt up all you have to do is redrill 3 holes!</TD></TR></TABLE>
only on the F22A heads.
budget + turbo aren't usually a good combo. especially if you're switching jobs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fizix »</TD></TR><TR><TD CLASS="quote">= ****.
Save that for the neons and mustangs.</TD></TR></TABLE>
explain yourself kiddo.
no I believe you but since his question was regarding F22 but didn't specify which F22 I thought I would clarify.
f22a, dsm manifold, f22b sothern fl performance, not many companies make manifolds for these f22b's.. I ran zex n20 at first.. it was a good kick..just get a manifold and build the piping..the accord is easy to do a turbo kit.. and you can beat the hell out of them and they wont blow as long as you tune it nice and rich.. low compression motor
