question baout my turbo LS
hey guys i just installed 8:5:1 pistons...with eagle turbo rods on my integra LS...and new rod bolts..and bearings...im also running a T3 turbo setup with a Garrett Turbo T3 .42 .48 i dont have any dyno results yet but im wondering if nayone knows maybe how muhc i will be making at the wheels and how much boost do you think i will make on this setup.....
Re: question baout my turbo LS (killablaze)
i dont think you are going to be very happy with the results. Why did you drop the compression, and run a tiny turbo? Even if you crank the boost up your going to run that turbo out of breath and its effeicency.
Re: question baout my turbo LS (notanotherSC61)
i plan on buying a bigger turbo setup.......I plan on upgrading the turbo to a t3/t40E 57. trim good for 490 whp...my t3 is just starting ot for rightnow...to put something in there....after afew months i plano dropping abigger turbo in the motor...so wat i did was build the motor and run this tiny turbo to see if the motor cant take it...after that ill drop the bigger turbo....
