225whp 162tq turbo gsr 6psi graph inside...
Hello here is my newly tuned GSR, and my dyno chart.
First here is my setup:
t3.t04e .63ar 57trim
custom manifold
tial 38mm wg
blitz dd bov
drag intercooler
drag piping
RC 310 CC injectors
Walbro 255
2.5in DP
ITR exhaust
chipped p28 w/ uberdata
Here are some shots of the car:
Me on the dyno
The dyno chart
custom manifold
tial 38mm wg
blitz dd bov
drag intercooler
drag piping
RC 310 CC injectors
Walbro 255
2.5in DP
ITR exhaust
Me on the dyno
The dyno chart
Re: 225whp 162tq turbo gsr 6psi graph inside... (eghatch4)
Im in the process of getting the rest of my stuff for my turbo setup. I hope to make numbers somewhere around yours or a little higher actually if possible.
My Setup:
Drag Manifold
t3/t4 (unknown specs?)
550cc injectors
walbro 255
turbosmart 35mm ultragate
rev hard intercooler
Im hoping that setup on my JDM GSR will make around 250whp on a good tune and low boost. I guess that Ill find out in a month or so
My Setup:
Drag Manifold
550cc injectors
walbro 255
the 310's are close, but not quite maxed...i was suprised we were able to run them.
let me know when you get the larger inj and exhaust...we can tune it for a little more.
not bad..i have gsr turbo hatch with t3/t4 on 7.2 psi..daily driven..have not tuned it but your dyno chart gives me an idea what i might be running..maybe faster on the street due to the weight of my car..but not bad
is it safe to drive stock gsr with t3/t4 turbo kit on 7PSI not tuned for a while? well atleast untill i get hondata and a good tune. or should i just wait and get it tuned and installed all together?
NO IS NOT OK TO RUN A TURBO CAR UNTUNED. Unless you wanna be rebuilding soon don't even waste your time putting in a turbo kit. 1. save money to have everything done at once. 2. save extra money in case of needing anythin else or braking something. Then you boost.
chihuahuamanx
04-19-2005 08:14 AM
