FITV, screw keeps backing out
Ok here's the problem...had idle problems with uberdata, sometimes rolling up to a light in neutral it would just die out. So recently i retuned on crome, took the FITV out, tightened it up, and fixed up my idle, sat at 900 no problem.
Within a week or two my idle started rising towards 2k and sitting there for a while, sometimes going down to 1500. Now yesterday and this morning it'll warm up then start surging from 1000 - 2500. I know it has to be my FITV screw that keeps backing out.
But what can i do to prevent tightening the screw every few weeks, its pretty annoying. I normally tighten it with a flat head and i'll push the screw as hard ask i can to make it tighten up. Do maybe i need a new screw cause mine is worn? Also what tool would be better to possibly tighten it up even more. The previous time i tightened it was like 7 months ago, but when it started getting colder, the crappy idle follows.
Any input/comments would be greatly appreciated. Thanks guys
Re: FITV, screw keeps backing out (DPSJosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DPSJosh »</TD></TR><TR><TD CLASS="quote">Loctite</TD></TR></TABLE>
Re: FITV, screw keeps backing out (CoreyR)
i believe there are two different kinds correct, a red and blue? which one is better to go with?
Re: FITV, screw keeps backing out (nY's FiNeSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nY’s FiNeSt »</TD></TR><TR><TD CLASS="quote">
i believe there are two different kinds correct, a red and blue? which one is better to go with?</TD></TR></TABLE>
Blue has a lower breaking point over red. I would highly reccomend using the blue if you must use loctite. Thread sealer will work just as well as will silicone and be a much better, less permanent solution.
Re: FITV, screw keeps backing out (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
Blue has a lower breaking point over red. I would highly reccomend using the blue if you must use loctite. Thread sealer will work just as well as will silicone and be a much better, less permanent solution.</TD></TR></TABLE>
thank you
thank you
joelmatt89
13
03-09-2009 07:03 AM
