Help with Kpro RSX turbo
I am stumped on this issue and need help from anyone that can possibly help
what are possible causes for an erratic idle?
here are my symptoms
vacuum reading is fine its about -14lbs
but the idle goes from 1000-2000 rpm
and the AF all over the place of course
the ignition goes from 0-6 values
I dont have any vacuum leaks
i checked the IAC valve and it seemed ok
what possible things could cause this or is it just tuning?
I have an rsx with 3 bar map gm kind, gt35r, any other details you guys need?
I use kpro to tune
anyone know the columns that belong to idle?
I use kpro to tune
Re: Help with Kpro RSX turbo (jsimon9633)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsimon9633 »</TD></TR><TR><TD CLASS="quote">columns 6-7</TD></TR></TABLE>
That isn't right. Unless you have ITB's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsimon9633 »</TD></TR><TR><TD CLASS="quote">so that means theres a vacuum leak right?</TD></TR></TABLE>
I would think so..
I would think so..
Alberto. I asked you if there was a vacuum leak earlier Unless you already hurt this motor there is a vacuum leak. I will look at it tomorrow when I wake up.
Re: Help with Kpro RSX turbo (0x64)
yes you asked me but to my knowledge there is not a vacuum leak
remember I have that vacuum manifold so really only a couple of spots it could be leaking from
the main hose coming from the brake booster to that vacuum manifold is one suspect, the others arent really considering I bought new vacuum hose from vacuum mani to wastegate and the one to map sensor and bov seem ok
There are a lot of vacuum lines on your motor. You could also have a vacuum leak some where on your intake manifold. A lot of places to check for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 »</TD></TR><TR><TD CLASS="quote">There are a lot of vacuum lines on your motor. You could also have a vacuum leak some where on your intake manifold. A lot of places to check for.</TD></TR></TABLE>
I bet that is what it is. Let us know if you fix it today!
Alberto. I will look at it before I leave Xavier's Thursday afternoon. If not I will look at it Friday.
email me some datalogs and your calibration file and ill look it over.
you've had bad luck with this damn thing so far man..
Unceasing Measure
Re: (mrbsponge)
The turbo RSX-S I put a GE Vacuum Manifold on didn't have any wierd idle characteristics. Then again, I tapped the IM plate for mine instead of using the BB line.
Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">he shoulda left the damn thing alone!@!!!@@!!
it ran fine before, but no...............</TD></TR></TABLE>
Mike. When I ran into Alberto he was getting one hundred to one hundred and twenty knock counts. Might have been engine noise but that's a little much for engine noise. That was the old engine though. This is the new one and things have changed. Not to mention the old kal was setup for closed loop.
Re: (0x64)
Mike. When I ran into Alberto he was getting one hundred to one hundred and twenty knock counts. Might have been engine noise but that's a little much for engine noise. That was the old engine though. This is the new one and things have changed. Not to mention the old kal was setup for closed loop.</TD></TR></TABLE>
what cal file was he using or which one did he use to tune with?
Re: (mrbsponge)
Mike the problem was that the car was tuned while the Knock sensor was malfunctioning( somehow that went bad while car was being tuned?)
and so it was horribly innacurate tune as far as knock, when I installed the new knock sensor it was knocking all over the place.
0h teh sl0w k20!!
07-09-2007 07:37 PM
darkd1gt
11
12-18-2005 04:27 PM
