turbo setup with vtec problems
Old Nov 19, 2005 | 05:56 PM
blues2k3's Avatar
Default turbo setup with vtec problems
I have a F20c turbo that is having intermittent problems with vtec engagement. When the motor is cold I get two or three passes on the dyno where vtec does engage. Once the car is warm the vtec then becomes inconsistent. I watched the oil pressure on each run and it remains the same at 80psi and goes up a bit. I cleaned the vtec screen a few times and also did some oil changes attempting to isolate the problem. Oil level is perfect and full. The solenoid was also tested electrically with a trigger wire and it does engage fine when manually triggered. I am using AEM also. Any thoughts? thanks
swapdohc
Apr 22, 2009 08:57 PM
JSpekBB4
Oct 30, 2007 10:23 PM
blues2k3
Dec 9, 2005 09:53 AM
hoya_10fintec
Feb 13, 2005 08:36 AM
MikeMAN
Mar 8, 2003 02:23 PM
