Oil pressure and oil lines questions
* B A N N E D *
I drained my oil and changed to a moroso pan , this is for a gsr and the moroso is the stock pan configuration. I also installed new oil filter , golden eagle sandwich adaptor and hooked in oil pressure sending unit and oil feedline into the sandwich. Now i wanna pressurize the system and get the oil moving through everything before i start it and get oil fed into the turbo. I took out the fuel pump fuse and cracked it but i had no oil coming from the oil feed line , is this normal . I cranked for at least 30 secs on and off. I dont wanna have the turbo spinning without good oil pressure in it and also in the head of the engine and whatnot . The car has been sitting for about 6 months.
Re: Oil pressure and oil lines questions (crxsiperf)
It's going to take forever for the motor to turn enough for there to be oil pressure. There are just not enough rpm's for the pump to start pump in a short amount of time. I was scared too when and I did the same as you are doing. However, it took too damn long so I just started the car and pressure came in like less than 5 seconds after starting.
Re: Oil pressure and oil lines questions (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc »</TD></TR><TR><TD CLASS="quote">It's going to take forever for the motor to turn enough for there to be oil pressure. There are just not enough rpm's for the pump to start pump in a short amount of time. I was scared too when and I did the same as you are doing. However, it took too damn long so I just started the car and pressure came in like less than 5 seconds after starting. </TD></TR></TABLE>
