Where to get Boost Guage Fittings (not T), That screw onto the back of the boost guage
Anyone know where i might be able to get these local? Anyone got a pic of what i should be looking for?
Re: Where to get Boost Guage Fittings (not T), That screw onto the back of the boost guage (Sick00Si
any parts store has them, try advance, i got one from there, u just gotta look.
Yeah, its a fitting that compresses the little ball inside right? Should i get the one that goes to normal vaccum like or the one that goes to the plastic lines that it came with?
Re: (abnaasefmb)
I've never had good luck with that autometer **** line. It kinks, and you'z screwed. I always use a regular rubber vac hose and fit it over a barb fitting on the back of the gauge.
Home depot is where I get the fittings. Plumbing section.
Re: (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 »</TD></TR><TR><TD CLASS="quote"> I've never had good luck with that autometer **** line. It kinks, and you'z screwed. I always use a regular rubber vac hose and fit it over a barb fitting on the back of the gauge.
Home depot is where I get the fittings. Plumbing section. </TD></TR></TABLE>
I agree...the autometer nylon line is a joke....I'd run either a stainless braided or rubber silicone line
stan
stan
Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">im going to run a braided line to mine, just looking for the female 1.8th npt to 3-an male</TD></TR></TABLE>
let me know if you need some, we have plenty of those
stan
stan
Who is Mr Robot?
Re: (Flamenco-T)
i will. i still need to send you those fittings like i said i was going to. i ahve a pretty severe concussion (had it for 3 weeks) so thigns come and go. ill pm you tomorrow iwth some questions
Re: (wantboost)
just go to the hardware store (ace even Napa or autozone) and get 1/8" compression fittings. I replaced my plastic lines with copper hard lines witch IMO are much easy to work with when you are faced with difficult mounting locations because the hard line can bend very tightly without kinking.
AB16A2T
05-29-2003 07:52 PM
