gsr turbo gone wrong
Old Nov 19, 2005 | 10:29 AM
weak_sauce's Avatar
Default gsr turbo gone wrong
i have a "98" gsr with ctr cams, blox IM, and a greddy kit with 310cc injectors, running with the greddy blue box, i recently just install the 310 injectors and up the boost to 10, when i drive it, at full boost around 4k the car would boggle and like back fire, like the back fire sound and the car wouldnt go anywhere beyond the 4 rpm at full boost, i can slightly gas the car and get beyond the 4k rpm but the car feels weird (hard to explain). the tech that did my car said it was turbo lag because i was using my stock gsr pipings, so i went and got 2.5 inch cat back piping but it still does the same thing...what could be wrong? ive heard the actuator or the wastegate could be damage but i am no sure or my cat is clogged?. any help would be appreciated! thanks
Old Nov 19, 2005 | 10:50 AM
ultradx's Avatar
Default Re: gsr turbo gone wrong (weak_sauce)
Get it tune with something beter. There is alot of options.
Old Nov 19, 2005 | 11:01 AM
93CX's Avatar
Default Re: gsr turbo gone wrong (ultradx)
get it tuned, and run open downpipe to see if its backpressure from a clogged cat.
Old Nov 19, 2005 | 11:30 AM
weak_sauce's Avatar
well as of right know i cant get it tuned, it is not an option as of yet, but what could be the problem? if i turn the boost down to 8, which i am, woudl it help ease the backpressure, but my friend ran 14psi with this kit and had not problem like this.? <confused>
Old Nov 19, 2005 | 11:43 AM
l337hxr's Avatar
misfire or preignition
Old Nov 19, 2005 | 11:51 AM
weak_sauce's Avatar
what is the difference? i dunno exactly of it is backfiring but it sounds like it??
Old Nov 19, 2005 | 11:56 AM
JDM_Risa's Avatar
Default Re: (weak_sauce)
try open downpipe first...since its building alot of pressure at 10psi right now....afterwards examine your plugs could be an ignition problem....
Old Nov 19, 2005 | 12:01 PM
weak_sauce's Avatar
okay i will try it, i am going to install the str8 pipe (test pipe?) first and see if that will help the problem.
Old Nov 19, 2005 | 12:25 PM
stockredej1's Avatar
also check your timing, your Timing belt may have slipped a tooth.
Old Nov 19, 2005 | 01:20 PM
nsxmatt's Avatar
If he was running the blue box and stock injectors then put in 310 injectors the car without doing anything for management it is running pig rich.
Old Nov 19, 2005 | 01:21 PM
xerox445's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weak_sauce &raquo;</TD></TR><TR><TD CLASS="quote">well as of right know i cant get it tuned, it is not an option as of yet, but what could be the problem? if i turn the boost down to 8, which i am, woudl it help ease the backpressure, but my friend ran 14psi with this kit and had not problem like this.? &lt;confused&gt;</TD></TR></TABLE>
Why is your car even turbo if you cant get tuned right now....bottem line.
honda1982
Sep 20, 2006 07:53 PM
Snail Tuning
May 15, 2004 07:42 PM
1boostedgsr
Mar 9, 2004 01:09 PM
Shaun K
Nov 21, 2002 03:39 PM
