best cams and springs/retainers to use on a lsvtec 2.0
so my buddy is building his lsvtec gsr 2.0 turbo and is buying his bottom end from JG and hes getting a gsr head and having it port and polished and 3 angle valve job etc. i was wondering what are a good set of cams to use for turbo..and same with springs and retianers and valves?
Re: best cams and springs/retainers to use on a lsvtec 2.0 (greddy13)
choice of cams usually are.. the crower 404's, ctr itr's for boost. oh and gsr's of course..
Modified by sirguy01 at 12:22 AM 6/27/2006
Re: best cams and springs/retainers to use on a lsvtec 2.0 (sirguy01)
id honestly say itr or ctr cams, but an aftermarket spring/retainer. ive heard of high boost pushing the valve keepers through the retainers.
i had stock b16 cams and noticed a difference when i put the gsr's in. the itrs should be even better
ITR or CTR camshafts seem to work great. I can't say for sure who makes the best springs and retainers. I personally use Super Tech but I highly recommend Ferrea as well. If you do end up going with an aftermarket springs and retainers be sure to also purchase recommended keepers as well. I know Ferrea sells recommended keepers with their valve train
b20vtech
03-08-2008 07:47 PM
1baddturbosi
01-27-2007 08:11 PM
