stainless lines off back of block for catchcan?
Old Jun 23, 2006 | 09:42 PM
.adam.'s Avatar
Default stainless lines off back of block for catchcan?
i plan on running a crankcase evacuation setup on my turbo gsr build and wanted to use the method of using the two honda barb fittings off of the back of the block. i was wondering if there was a way to run stainless lines off of the barb fittings somehow. i always see them used off of the valvecover, but they arent used with barb fittings. can someone help me out? sorry for the noobish question but i did search!
Old Jun 23, 2006 | 09:52 PM
96 GSR-T's Avatar
Default Re: stainless lines off back of block for catchcan? (civicskater)
Take the Honda fittings and cut off the barb, weld on a 10 or 12 an fitting and presto......
Old Jun 23, 2006 | 10:04 PM
.adam.'s Avatar
is there any solution that doesnt involve welding?
Old Jun 23, 2006 | 10:21 PM
BrokeAssWhiteboy's Avatar
my house has wheels on it
Default Re: (civicskater)
don't you wish you had one of these....
Old Jun 23, 2006 | 10:25 PM
96 GSR-T's Avatar
Default Re: (BrokeAssWhiteboy)
LMFAO ^^^
Old Jun 23, 2006 | 10:37 PM
speeddave's Avatar
Default Re: (96 GSR-T)
why not use a hoseclamp? you can even get those an fitting look alike things with the hoseclamp in them if you want the look.
Old Jun 23, 2006 | 10:50 PM
a1320addict's Avatar
Default Re: (speeddave)
Z10 carries the fittings in -12 AN.
Part # Z10-4006
http://www.z10eng.com
Old Jun 23, 2006 | 11:00 PM
96 GSR-T's Avatar
Default Re: (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">Z10 carries the fittings in -12 AN.
Part # Z10-4006
Lol.... how much are those? Prob $40 a piece from Z10
Old Jun 24, 2006 | 12:25 AM
ImportMotorSpec's Avatar
I have stainless lines off my honda fittings, unmodified. I can't remember if it is -8 or -10 that fits it snug with a worm drive clamp. Im pretty sure it is -8. Just take the fitting to your parts store and see which line fits it snug. I then just took earls fittings and connected everything together.
This is a very expensive way to do it, let me tell you. I think i had $150 in just fittings, but it looks very nice.
B20vtec veteran
Sep 19, 2013 01:33 PM
thatcivic96
Jan 20, 2013 12:20 PM
spAdam
Mar 2, 2012 03:35 AM
SequenceGarage
Welding / Fabrication
13
Dec 30, 2006 01:14 PM
RuthlessEF-9
Oct 25, 2005 07:56 PM
