WILL OB1 INJECTORS WORK ON OBD0 ENGINE
Old Jun 22, 2006 | 02:58 PM
baldmofo's Avatar
Default WILL OB1 INJECTORS WORK ON OBD0 ENGINE
I built a turbo motor now the last thing I need is the injectors I looked and looked but cant find any info. All the injectors I see are obd1 my b16a is obd0 will the obd1 injectors work ?
Old Jun 22, 2006 | 03:50 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Default Re: WILL OB1 INJECTORS WORK ON OBD0 ENGINE (baldmofo)
yep they will work... just be sure to find out if they are peak and hold or saturated
Old Jun 23, 2006 | 10:35 AM
baldmofo's Avatar
Default Re: WILL OB1 INJECTORS WORK ON OBD0 ENGINE (1QwIkEf)
Im going to be running peak and hold. Do I need the clips too or will my stock ones work
Old Jun 23, 2006 | 02:18 PM
1QwIkEf's Avatar
if your cqar is obd-0 then you will be fine
Old Jun 23, 2006 | 07:01 PM
baldmofo's Avatar
thanks for the info man
Stiff_Crx
Jun 18, 2010 04:43 AM
ReactioN
May 22, 2008 06:31 PM
hondacivic90zc
Mar 6, 2007 06:02 PM
b16powwer
Jul 27, 2003 03:08 AM
