Another Lsvtec question pls help me im ready to put my lsvtec turbo setup
B A N N E D
Location: Orange County / Palm Springs 714/76hoe, ca, usa
hi ht member
well im about to put my lsvtec t setup and just wanna know where to put the dowel pins can i see a pic of where do i put the dowel pin thats alot
B A N N E D
Re: Another Lsvtec question pls help me im ready to put my lsvtec turbo setup (SPNFEDEH)
So so which one do you guys prefer to use the second method(ilike this one cuz its easier) or the first method (which is complecated and hard to do)???
Or I need to do both
Thanks alot
Thanks alot
Re: Another Lsvtec question pls help me im ready to put my lsvtec turbo setup (spoon95eg)
get the golden eagle lsvtec kit and be done with it
doesnt require any machine work
B A N N E D
Re: Another Lsvtec question pls help me im ready to put my lsvtec turbo setup (komat)
I know but I already have the dowel pin feedline and sandwich for cheap unless if the ge sell the dowel pin separate that awesome
But yea second method? or first method? Or both?? Pls help me
yes they sell the ge dowel pins by itself.
so none of the methods
B A N N E D
Nice ill get onethank you
So if I buy the ge dowel pin where do I put it ,? Pic request so I can put this project together
Thanks
Thanks
i dont have a picture of mine but you will know.**** you will have to modify the head gasket just a little bit still because the dowels are bigger,the GE headgasket is already modified,if you dont have a headgasket yet,get the GE one.
i think the dowels go on the intake side...i dont remember exactly
B A N N E D
Re: Another Lsvtec question pls help me im ready to put my lsvtec turbo setup (eg6T)
Oh ok ill get the ge hg but I need the pic or to really tell which hole to put the dowel thanks
if u get the ge headgasket u will know for sure,because the headgasket is modified for them,so there is only one place then can go...
ge lsvtec headgasket are p30(b16a) headgasket bore to whatever size you want
as for the dowel pins on where they go. they go to the exhaust side
B A N N E D
Where on the exhaust side both side?dizzy side?tb side?
And do I need to put a dowel pin to intake side to both side? Dizzy side? Tb side?or non?
Thanks man
Thanks man
B A N N E D
Pic request where to put the dowel pin
looks like you need to do more research...
with the ge dowel pins they go in the stock location of the head
which are the outer ones ont he exhaust side
B A N N E D
So I'm getting the dowel pin from ge right its 2 dowel pin so I'm gonna put one in exhaust side(tbside) and one on the exhaustside (dizzyside) too
I know I need to research more
Ready for a loop. I put mine on the intake side (stock LS location). I use the GE dowels, get them, so easy.
Re: Another Lsvtec question pls help me im ready to put my lsvtec turbo setup (Doodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doodoo »</TD></TR><TR><TD CLASS="quote">Ready for a loop. I put mine on the intake side (stock LS location). I use the GE dowels, get them, so easy. </TD></TR></TABLE>
thats where mine are too...u cant put them anywhere else if you are using the GE headgasket,unless you want to modify the already modified headgasket...
i have a b16 head,maybe its a different location for a gsr head??
B A N N E D
Can u please tell me where to put it <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T »</TD></TR><TR><TD CLASS="quote">thats where mine are too...u cant put them anywhere else if you are using the GE headgasket,unless you want to modify the already modified headgasket...
i have a b16 head,maybe its a different location for a gsr head??</TD></TR></TABLE>
I have a b16 head so where am I gonna put it intake dizzy side or intake tbside
And do I put one on the exhaust same question^
Thanks a lot
Ps that s the last question and I'm done (where to put it)
Thanks please answer the question
Thanks a lot
there are only 2 spots on the intake side,they will go into those spots
you will not put any on the exhaust side.
if you put up a picture of the top of your ls block ill tell you where...
