someone please help me!!!
Old Jun 25, 2006 | 12:24 AM
lsvtecSIrex's Avatar
Default someone please help me!!!
im gonna light this thing on fire!!! what would make a car run perect, pulls smooth and hard, then 5 minutes later run like **** and barely move, sputter, idle rough, pop and back fire and then run like that the rest of the night? im so tired of this damn motor.
it ran like ****, then i found the map sensor was leaking, fixed it, ran perfect for a few pulls, shut her down, and its ran like **** ever since. map sensor is still good. steady fuel pressure and its still leaning out. i dont know tuning **** but the boost map is supposed to make it run crazy rich... its definatley not tho. its retarded 1 degree per pound of boost. cam gear is at zero. it'll get worse and worse the more i drive it. no codes. i cant find any more vaccum leaks but im gonna search like crazy tomorrow.
its a mini-me, 14b turbo, msd blaster coil, open down pipe, 440 injectors, adjustable fpr, pr3 ecu with boost map.
i just thought of this while i was reading this. the 440's r obd1 and im running a resistor box still, is that a problem? what would make it keep running worse and worse?
someone help before i ditch this whole car
Old Jun 25, 2006 | 12:27 PM
anyone
Old Jun 25, 2006 | 12:32 PM
qfast817's Avatar
Default Re: (lsvtecSIrex)
check for bent valves, and re set your timming also is the car tuned?
Old Jun 25, 2006 | 12:42 PM
bent valves could cause that? didnt think of that. that means i have to pull the head off huh.or just do a leak down test? and i cant tune it until it runs better, its just got a base map right now
Old Jun 25, 2006 | 03:38 PM
any ideas?
Old Jun 25, 2006 | 05:35 PM
coneheadsracing's Avatar
What minime, and what ecu is a pr3? What program are you using? I def don't know everything by a long shot, but i've never heard of map sensors making your car run rich. I think you need some tuning, base maps are for driving easy on, so you can go get it tuned. However, setup properly they will work fine also. I used to have issues with over-heating, and wouldn't be able to get into boost, unless i revved it up and poped the clutch, once in boost it was fine. I don't know.
Old Jun 25, 2006 | 05:52 PM
DaveF's Avatar
Default Re: (coneheadsracing)
wow... similar to a problem 93turbo16 is having........
Old Jun 25, 2006 | 06:05 PM
its a obd0 b16 ecu. he used BRE to chip it. doesnt over heat. boosts fine once the rpms get up there but i wont take them up cuz its running lean and it stutters like crazy
Old Jun 26, 2006 | 11:35 AM
I don't know what BRE is, but if its like crome uber so on, make sure you fuel maps are good, specialy in the areas you are leaning out. Also, maybe swap out distributors with someone else. I've heard of heat getting to those.
Just to clarify, is it always running bad now, or just after it starts to heat up?
Do you have a temp guage in, when mine was doing it, it never would have registered on the stock temp guage, just noticed it cuz i had an autometer installed.
Old Jun 26, 2006 | 11:50 AM
seems like its always running bad now, im tryin a new map sensor today and a new base map and c if that helps
Old Jun 26, 2006 | 12:25 PM
boston's_rex's Avatar
i dont know if this will help but i had something like that with my car a cuple of years ago and it turn out to be my msd set up put the stock one back and it was fine p.s my car was not turbo hope this helps
Old Jun 26, 2006 | 06:38 PM
cars fixed. new map sensor, new base map, and messed with timing more... and yes i ditched my msd coil
Old Jun 29, 2006 | 10:05 AM
i love a happy ending!
jthrasher1
Nov 30, 2009 12:34 PM
h22sedan
May 6, 2007 02:59 PM
rdssk8rcs1
Oct 10, 2006 06:43 AM
Crazy Cooter
Nov 4, 2003 05:02 PM
Greyout
Jan 25, 2002 09:08 AM
