bad wastegate or turbo?
Ok I'm still stumped
My wastegate (hks) has a 9.7# spring but it seems the most boost I can ever make is 6.5#'s. I've even unhooked the wastegate line and still 6.5#'s. I'm 95% sure there's no leaks in the piping/exhaust.
Is there anyway to narrow down what could be wrong? Here are the few idea's I have, think they'll work?
-Remove the wastegate and see if I notice anything wrong (dont have much to compair it too though)
-try blocking the wastegate off on the manifold and do an easy run without a wastegate.
If I run w/o the wastegate and it still only make's 6.5#'s is there a way to tell if it's the turbo or if it's a leak somewhere? I know it could overspin the turbo but I don't have any other ideas.
Any help is appreciated as I'm pretty stumped
Re: bad wastegate or turbo? (4_door_teg)
I have all my vacuum lines hooked up to a vacuum manifold t'd off the break booster line.
I do not have a boost controller. That just reminded me that the nipple on the top of my wastegate isn't hooked up to anything. I remember reading somewhere that it didnt matter. Does it?
Re: bad wastegate or turbo? (93turbo16)
Tonight I popped a vacuum line off and hooked my compressor up to it. Put pressure in the system and didn't hear/feel any leaks at all. You can hear the wastegate clicking open and also feel air shooting out of the top nipple.
Any thoughts?
Any thoughts?
I also just thought of this. I bought the turbo with the internal wastegate flapper thing welded closed. Possible that this was screwed up and is causing my problem?
im having hte same problems
i been checking for leaks all week
cant find one yet
i need to pressureize the system
7.25lb spring>4lb
3.6lb spring>2lbs
Modified by importdude2000 at 11:33 PM 6/25/2006
cant find one yet
7.25lb spring>4lb
3.6lb spring>2lbs
Re: (4_door_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4_door_teg »</TD></TR><TR><TD CLASS="quote">no filter, just a cut out strainer lol</TD></TR></TABLE>you have a boostleak somewhere
is it possible that the weld job on the internal wastegate screwed up or something?
I can't find a leak ANYWHERE. Whats the best way to find a leak? and how big is a 3# leak gonna be?
if u unhook the wastegate line and u only get 6 psi it sounds like to me you have a boost leak somewhere in the ic piping or the turbo is no good but it still should make more with the wastegate source unhooked
DaYZeD.1
03-28-2008 06:54 AM
