dowel pin fitment on the ls block? a lil loosee
B A N N E D
Location: Orange County / Palm Springs 714/76hoe, ca, usa
like the title says i doing an lsvtec and i alrady found out where to put the dowels so i tried it today and the fitment alil loose (easy to put on)(not like when u put it to the head fitment not to easy not hard but i thinki ts alright but i dont know if that s how it is ?
btw im using a stock dowel pin
if i use the ge one would it be perfect fit like not hard and not to easy
thank s
thank s
Re: dowel pin fitment on the ls block? a lil loosee (spoon95eg)
just to let you know that you should use a Golden Eagle down pin kit the GE dowlpin has two sides that are different sizes..... the LS has a different size dowle pin than the GSR or SI..... it sounds like your trying to use a B16 or B18C dowlpin in the LS block which wont work
B A N N E D
Re: dowel pin fitment on the ls block? a lil loosee (BoostedEG6)
Oh ok so I guess I have to buy the dowel pin hahaa thanks
Rhymenoceros
03-06-2006 11:11 PM
