GUesS How Much HP would I make on the 1st setup vs 2nd setup??
B A N N E D
Location: Orange County / Palm Springs 714/76hoe, ca, usa
I'm deciding if I should do the first one for low cost or 2nd one for $$$$
Here yall go 1st setup I'm thinking
Lsvtec
B16a head PNP
Itr cams (96-98)
supertech chrome valve standard size
Supertech valve spring retainer
(I guess that fully built )
Skunk 2 manifold
Gsr tb
750 or 1000cc inj.
Walbro 255
Ls block (unknown miles)
I'm putting a new piston ring new bearings and main stud and rod stud(ARP)
Stock piston and rods
T3/t04e .50cold/.63hot
Precision 350 fmic
Hks bov
2.5 ic piping
38 mm wastegate
Equal length mani
3'dp exhaust back
Crome pro
Gsr tranny non lsd 6 puck unsprung
I'm thinking 12-15 psi
2nd same head upthere^^
Ls blockwith
9:1 cp piston 81.5 mm
New oem ring
Eagle rods
Arp main stud and rod
Acl bearing
Same turbo setup
Same tranny ^^
Same psi goal
OR 2nd setup sleeve block 83mm(so I can rebore it when somethiing happen
My goal is 350 up atleast on the setup
Duable YES NO
Thanks
Jeff
Lsvtec
B16a head PNP
Itr cams (96-98)
Skunk 2 manifold
Gsr tb
750 or 1000cc inj.
Walbro 255
Precision 350 fmic
Hks bov
2.5 ic piping
38 mm wastegate
Equal length mani
3'dp exhaust back
Crome pro
Ls blockwith
New oem ring
Eagle rods
Acl bearing
Same turbo setup
Same tranny ^^
Same psi goal
Duable YES NO
Thanks
Jeff
B A N N E D
Re: GUesS How Much HP would I make on the 1st setup vs 2nd setup?? (spoon95eg)
Noone hahahah gueess how mucj people
B A N N E D
Re: GUesS How Much HP would I make on the 1st setup vs 2nd setup?? (a1320addict)
Hey I'm just asking if my hp goal is about right on my setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict »</TD></TR><TR><TD CLASS="quote">This is retarded.</TD></TR></TABLE>
LOL
Good luck man
LOL
Good luck man
You obviously need to do much more research before you ask this question. That being said........I would gusstimate between 320 and 350 whp on either setup. Having forged internals will not make you more power. I personally would not try to make that much power on stock internals and pump gas. Maybe that's just me though. GL.
B A N N E D
Re: GUesS How Much HP would I make on the 1st setup vs 2nd setup?? (KeyserSoze)
That what I want to hear anymore suggestions
