HELP, PLEASE!
Old Jun 27, 2006 | 05:20 PM
baxter04's Avatar
Default What could be wrong, please help!!!!!!!!!!!!!
I have a 97 Honda Civic with an H22 Swap. I was running it all motor at first, ported head and dynoed at 218 with a Hondata. I decided to turbocharge it using a thicker head gasket to drop compression (T3/T4 Turbo, small intercooler and with a 38 mm Tial Wastegate) and got it tuned with Hondata S200. Watching the dyno screen, when VTEC kicks in at 5200 rpm, horsepower/torque would drop by 20 hp then it would pick up again. On the otherhand, when VTEC was set at 6000 rpm, it would only drop 8 hp, then picks up again. Ignition and AFR are both where it should be. VTEC function was verified as well as oil pressure. No CEL at all.
I'm faced with two issues right now.
1. Horsepower drops when VTEC kicks. When VTEC is set at 5200 or 5500, hp drops by 20 and when it's set at 6000 rpm, it only drops 8. Boost holds when VTEC hits but power drops.
2. Max boost is 6 lbs when I have a 10 lb. spring. Boost does not hold, would lose 1 lb after 7000 rpm.
I did not have that VTEC problem when it was all motor. Only thing done to the motor was to replace the head gasket.
Modified by baxter04 at 2:36 AM 6/28/2006
Old Jun 28, 2006 | 10:40 AM
baxter04's Avatar
Default Re: What could be wrong, please help!!!!!!!!!!!!! (baxter04)
Anyone????????
Old Jun 28, 2006 | 10:57 AM
qfast817's Avatar
i had the same problem with the waste gate, i used a smaller hose and itll pick up
b-series-em1
Apr 29, 2009 07:16 AM
civicboy1128
Engine Management and Tuning
12
Jan 12, 2009 09:15 AM
baxter04
Jun 30, 2006 09:11 PM
tegturbo
Jul 19, 2005 10:10 AM
sharkcohen
Jul 7, 2003 10:03 PM
