does it matter what spring i use in the wastegate with an electronic boost controller?
Old Jun 22, 2006 | 05:44 PM
vladd's Avatar
Default does it matter what spring i use in the wastegate with an electronic boost controller?
like the title says, does it matter what type of spring i use in the wastegate if i'm going to be using an electronic boost controller?
Old Jun 22, 2006 | 05:49 PM
SpeedingHatch's Avatar
Default Re: does it matter what spring i use in the wastegate with an electronic boost controller? (civicdxt
some might have a harder time holding boost if the spring is weak. Figure out what kind of boost you want, then find a spring thats like 75% that, then use the boost controller to compensate.
just my opinion
Old Jun 22, 2006 | 05:51 PM
boostedcivicsir's Avatar
Mr. Badwrench
yes. the lower the spring the harder to hold high boost consistently. if it is too stiff, you CANT run low boost.
Old Jun 22, 2006 | 09:04 PM
vladd's Avatar
i bought the wastegate used, so i have no idea what kind of spring is in there. is there any way to tell? will it have some kind of marking on it?
Old Jun 22, 2006 | 09:19 PM
TypeSLO's Avatar
what wastegate is it? TiAL uses color and two different diameter springs. look on their website.
Old Jun 27, 2006 | 02:53 PM
vladd's Avatar
ok, i just took the spring out. it's red, and about 4" tall. would this be the "big" one or the "small" one? according to this, there are two different sizes of springs. i just can't find anywhere that says the size difference between them.
regardless of size, i can adjust the boost lower or higher than what the spring is rated for, right? i've looked through some archived topics, and some people say the spring psi is the minimum you can run, while others say that you can adjust up or down, just within a reasonable amount. if my spring is the "big" red one, that means that its made for 11.6 psi. i'm planning on running around 8. would this work?
Old Jun 27, 2006 | 03:05 PM
PH_B16-VTi's Avatar
I was told that the spring is the minimum you can go and the controller can controll from there and up... But I'm def. not an expert on this.
/ph
Old Jun 27, 2006 | 03:07 PM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PH_B16-VTi &raquo;</TD></TR><TR><TD CLASS="quote">I was told that the spring is the minimum you can go and the controller can controll from there and up... But I'm def. not an expert on this.
/ph</TD></TR></TABLE>
correctomundo.
the lowest boost you can run, is what ever the sping is set for. and from that point you can increase with a controller.
Old Jun 27, 2006 | 03:15 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
correctomundo.
the lowest boost you can run, is what ever the sping is set for. and from that point you can increase with a controller.</TD></TR></TABLE>
so there's no way to run lower psi than what the spring is designed for?
Old Jun 27, 2006 | 03:24 PM
Mr. Badwrench
less cutting coils out of it, no. unless it is an internal wastagate with a rod that is adjustable and you can lengthen it. but even then you can only go a little.
Old Jun 27, 2006 | 03:44 PM
vladd's Avatar
alright. would you happen to know the difference in sizes between the big and small springs?
Old Jun 29, 2006 | 05:00 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">alright. would you happen to know the difference in sizes between the big and small springs?</TD></TR></TABLE>
does anybody know the size difference? i'm wondering if the spring i have right now is a small or big one.
Old Jun 29, 2006 | 05:14 PM
dpetro1's Avatar
the springs go by color and diameter. tial uses the same springs for all wg sizes. there is a "big" and a "small" and each has various colors. in the link you posted it tells you the diameter of the 2 types springs. this info can also easily be found on tial's website.
the small springs all have a 1.875" OD and the large springs all have a 2.36" OD. so just measure the one you have and go from there. like others have said you cannot boost lower than the spring pressure.
Old Jun 29, 2006 | 05:23 PM
vladd's Avatar
alright, thats what i needed to know. turns out i have the big one then, i'll have to get a new one. thanks for the info guys.
edit: expletive i'm blind. the diameters are listed in the other thread, i just didn't notice.
Modified by civicdxtyper at 7:48 PM 6/29/2006
powerdbygarrett
Jul 3, 2008 01:50 PM
LSEGHATCH
Dec 15, 2004 10:51 PM
CIVILGSR
Jul 9, 2003 08:53 AM
shingles
Jan 24, 2003 01:58 AM
wonny
May 30, 2002 03:18 PM
