How much HP will I get with this setup..?
Old Jun 26, 2006 | 02:04 PM
srg's Avatar
srg
Default How much HP will I get with this setup..?
Hello,
My car is 93 del sol si (D16z6)
My setup is:
SLS Manifold, Downpipe, Dumptube...
GARRETT T3/TO4E 50 Trim .48 A/R - 4 Bolt Exhaust
Tial 38mm Wastegate (0.5 bar spring)
440cc RC saturated injectors
Edelbrock Performer X intake manifold
Precision 350HP intercooler..
Engine is stock.
How much HP will I get with this setup?
Old Jun 26, 2006 | 03:07 PM
Teg4e's Avatar
Default Re: How much HP will I get with this setup..? (srg)
180-200whp?
Old Jun 26, 2006 | 04:02 PM
hotimportcrx's Avatar
Default Re: How much HP will I get with this setup..? (Teg4e)
on a good tune you can make 220-240whp on that setup and have be nice and reliable
Old Jun 26, 2006 | 04:52 PM
Teg4e's Avatar
Default Re: How much HP will I get with this setup..? (hotimportcrx)
I don't think so with 7psi on a 50trim t3/t4.
Old Jun 26, 2006 | 04:59 PM
defiently not on 7psi lol......your gonna need more then that ...im saying around 11 or 12psi...on a good tune your fine...unless you plan on running just wastegate spring (i see u have a 7psi spring) then you wont get there.
Old Jun 26, 2006 | 07:49 PM
nerdsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotimportcrx &raquo;</TD></TR><TR><TD CLASS="quote">defiently not on 7psi lol......your gonna need more then that ...im saying around 11 or 12psi...on a good tune your fine...unless you plan on running just wastegate spring (i see u have a 7psi spring) then you wont get there.</TD></TR></TABLE>
i'm running a similar setup (same turbo, short tubular manifold, 2.5-3'' downpipe, 440cc injectors) and on 12.5-13psi i made 273whp. on a stock head and block btw.
Old Jun 27, 2006 | 12:58 PM
srg's Avatar
srg
I can run 7psi spring and use boost controller to up the boost
a1320honda
May 9, 2013 01:13 PM
turboed-single-cam
Oct 28, 2007 08:34 PM
srg
Jul 7, 2006 02:53 PM
srg
May 27, 2006 01:13 AM
slowteg550
Jan 25, 2006 07:07 PM
