boosting too high
ss auto external wastegate, i can't limit the boost. It just keeps going pass 10 psi in my h22. I have a manual boost controller. Is the MBC faulty or the wastegate? or my vacuum routing?? the wastegate to manifold flange is leaking a bit.
do this, eliminate the controller, hook the wastegate bottom port directly up to the boost signal. if it is the correct spring, it should that 7 or 8 psi depending on what it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gooseman »</TD></TR><TR><TD CLASS="quote">ss auto external wastegate, i can't limit the boost. It just keeps going pass 10 psi in my h22. I have a manual boost controller. </TD></TR></TABLE>
is the MBC pressure source/outlet hooked up backwards? if it is you'll get unlimited boost.
turbodan4
Mar 7, 2006 09:09 PM
