Difference Between 90-93 Integras???
Old Jun 11, 2004 | 02:03 PM
Geeq's Avatar
Default Difference Between 90-93 Integras???
I'm asking Engine Codes between RS, LS, GS, GSR.
Also what are the trim levels?
Some have painted body moldings and some don't. Which are which?
Any info will help.
Old Jun 11, 2004 | 02:27 PM
aznballer's Avatar
ls,rs,gs in90- 91 have b18a w/ 130 hp
in 92 93 they have 140hp
gsr in 92-93 have 160hp
i kn gsr's have painted moldings
Old Jun 11, 2004 | 02:51 PM
importdude2000's Avatar
ls-s and gsr has painted moldings
gsr will have painted Vtec molding on fender...
gsr doesnt have a 3rd brake light
trim levels
ls,rs,gs,gsr,ls-s
Old Jun 11, 2004 | 03:04 PM
mugen92acintls's Avatar
Default Re: (importdude2000)
90-91 is pre-obd and 92-93' are obd-1. The difference between the pre-obd and the obd-1 power-plants from 90-93 are the exhaust manifold, on board diagnostics, and the fuel pressure. The only real way to figure out what motor you have is to check out the exhaust manifold, if it has a double down-pipe, then its OBD-1, if it only has a single down-pipe, then you have a 90-91 B18A1. the 92-93 Integra GS-R came with a dohc vtec dubbed the B17A. The trim levels are easy. The RS is the base model w/ manual windows, locks, no moonroof or spoiler, the Ls which is next in line has manual locks, power windows, moonroof, power antenna, and A/C. The top of the line Gs has the power locks, power windows, power moonroof, A/C, ABS, alloy wheels and rear spoiler. The 90-91 boasts 130 hp. and the 92-93 Obd-1 power-plant produces 140 hp at 126 ft.lbs. of torque. The engine codes are all the same from 90-95 integras, they all have the B18A1.
Old Jun 11, 2004 | 03:28 PM
RPRacing's Avatar
hate to do it on a topic i know a bunch about, but it (like most general info questions) has been answered many times before. please search
jdmbeegee
Sep 6, 2006 12:13 AM
hatchydude
Mar 12, 2006 08:05 PM
mannyfresh2.0
Jan 24, 2006 05:22 AM
hyperazn108
Aug 9, 2004 07:26 PM
