Oxygen Senor (DC2) - When do you replace?
Search Results (Archived)
Your search for oxygen returned 13 results.
All of which didn't tell at how many miles is recommended to change your oxygen sensor. Roughly when should the oxygen sensor be changed?
Thank you.
New User
Re: Oxygen Senor (DC2) - When do you replace? (Xymox007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xymox007 »</TD></TR><TR><TD CLASS="quote">
Thank you. </TD></TR></TABLE>
when it doesnt work anymore.
thats pretty much the basics of it. if its throwin a code or causing your car to run bad due to incorrect air/fuel readings, then replace it.
Re: Oxygen Senor (SIK IN DA HED)
Okay, I wasn't sure if it was a preventative maintenance item, or should be changed like spark plugs.
Thanks.
Thanks.
MacMade
03-18-2015 06:42 AM
h22_crx
05-06-2008 10:07 PM
Mrs . M i c h a e l
03-18-2006 11:10 AM
