clutch ?
Old Jun 11, 2004 | 08:15 PM
luvinmyGSR's Avatar
Default clutch ?
my clutch is making this squeakin sound every time i push it in...and it did not do this when i bought the car...is this a bad thing
Old Jun 11, 2004 | 09:34 PM
IMMORTAL-B18's Avatar
Default Re: clutch ? (luvinmyGSR)
Mine did this for a little bit. Its was more of a sound like the cable skipping thru whatever it is ran thru. It doesnt do it too much anymore. I read a post somewhere about where to lube it. I cant remember where though. Maybe someone one here will remember & post the link. I am bored so I will go hunting for some info.
Here is one: Last Post
Another: Find Post By "tegboi"
These maybe something related. Try searching this board as well as This One to see if someone has a similar problem and the solution.
Modified by IMMORTAL-B18 at 10:49 PM 6/11/2004
Old Jun 11, 2004 | 09:40 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: clutch ? (IMMORTAL-B18)
It's almost 100% your throwout bearing.
Most of the time, it should be replaced when a new clutch goes in. Sometimes, people are lazy and keep the old on in there. It's not too bad, but it will squeak until you get a new one. I'm sure it'll last long enough until your next clutch change.
Old Jun 11, 2004 | 10:21 PM
AirWaveGT's Avatar
Default Re: clutch ? (shamoo)
mine is doing the same thing right now, not every time i push it in but most of the time. my friend said that he had the same problem before and it was the throwout bearing on his car. Im just putting in a whole new clutch soon so that should solve my problem. already have the clutch and flywheel here, just need to get it installed
Old Jun 12, 2004 | 08:05 PM
luvinmyGSR's Avatar
Default Re: clutch ? (AirWaveGT)
k well im gettin a new clutch and fly wheel in liek 2 weeks...jus around how much am i looking at to get it installed...i want to learn to do it myself i jus dont have the time to learn ...i need to get to work etc...
Old Jun 12, 2004 | 08:14 PM
mpintegra96's Avatar
throwout bearing
Old Jun 12, 2004 | 09:31 PM
luvinmyGSR's Avatar
Default Re: clutch ? (mpintegra96)
bump
Old Jun 13, 2004 | 07:50 AM
AirWaveGT's Avatar
depends on how much the shop you go to charges for labor. it should be around a 3-5 hour job i think
Old Jun 13, 2004 | 09:42 AM
IntegraBoy04's Avatar
Can you change just the bearing?
Old Jun 13, 2004 | 08:08 PM
luvinmyGSR's Avatar
Default Re: clutch ? (IntegraBoy04)
i think u can just change the bearing but i am jus gettin a new clutch and flywheel
Old Jun 13, 2004 | 08:56 PM
Sack Master's Avatar
Are you sure it's not the pedal?
miguey310
Sep 2, 2009 04:20 PM
renes
Nov 21, 2005 11:25 AM
NOahFATCHICS
Oct 20, 2004 04:20 AM
blueluder
Sep 20, 2003 02:04 PM
cr00klyn718
14
Dec 2, 2002 11:06 AM
