bouncing rev limiter
Old Jun 10, 2004 | 07:01 AM
.M.'s Avatar
.M.
Default bouncing rev limiter
i was being a dumbass and was driving recklessly in country road.. had the music up pretty loud and forgot to check to shift. i check my tach and i see the rev bouncing and quickly shift. i was on 2nd gear. anything could of happened or am i fine?
Old Jun 10, 2004 | 07:02 AM
warrick's Avatar
Default Re: bouncing rev limiter (JH4DC4)
that depends on how long you were there...
how do you forget to shift though? don't you run out of power before fuel cut?
Old Jun 10, 2004 | 07:16 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: bouncing rev limiter (warric_k)
No, you're fine. That's why the rev limiter is there. You could have sat there bouncing off of it most of the day and you'll be fine.
Well....maybe not most of the day....but you know what I mean.
Old Jun 10, 2004 | 07:21 AM
JiggyKooAndy's Avatar
Default Re: bouncing rev limiter (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">No, you're fine. That's why the rev limiter is there. You could have sat there bouncing off of it most of the day and you'll be fine.
Well....maybe not most of the day....but you know what I mean. </TD></TR></TABLE>
it will wear on the engine because every other second the engine is getting fuel...then not....then it is...then it's not. Not good for the engine.
Back to the original question...u should be fine, but if your really worried, do a compression test to be sure.
Old Jun 10, 2004 | 09:29 AM
B00ST2nR's Avatar
thats the whole point of a Rev limitter. You're fine.
TonyRomo
Jan 8, 2009 06:27 AM
fili_pinoy
Honda Civic (2006 - 2015)
30
Feb 16, 2007 04:32 PM
HamiltonRex
Jul 18, 2006 07:42 PM
R-Rated
Jun 22, 2001 01:11 PM
