JDM Conversion Questions
Old Jun 9, 2004 | 03:03 PM
JaY-R's Avatar
Default JDM Conversion Questions
Here's a question about wiring the lights to the JDM headlights...
did you have to get a new connector and splice the usdm wires into it???
cuz looking at the usdm connectors.. i didn't see anything that would hook up to this connector...
Old Jun 9, 2004 | 03:20 PM
..::91TEG-G2::..'s Avatar
Default Re: JDM Conversion Questions (b18bb0y)
nice feet...
na but i thought when you get the kit, it comes with all the wiring harnesses for the lights.. someone correct me if im wrong
Old Jun 9, 2004 | 03:36 PM
IntEGNYC's Avatar
Default Re: JDM Conversion Questions (..::91TEG-G2::..)
DA Feet!
Old Jun 9, 2004 | 04:06 PM
JaY-R's Avatar
Default Re: JDM Conversion Questions (IntEGNYC)
LOL.. whatever
i just took pix real fast so i can get an answer!!! =P
and.... i pieced together my kit.. so i didn't get anything for the connectors...
there's a piece i need?
Old Jun 9, 2004 | 04:43 PM
JaY-R's Avatar
does anyone know?
Old Jun 9, 2004 | 05:00 PM
MENACEteg's Avatar
I didn't use a new plug on my headlights, I just used two connectors and wired it into the stock wiring. I suggest covering the connectors w/ electrical tape to help prevent corrosion. Hope this helps.
Old Jun 9, 2004 | 05:02 PM
DIY's Avatar
DIY
Default Re: JDM Conversion Questions (MENACEteg)
if you didnt get the harness with your lights just use spade connectors to attach the wires. if you need anymore help let me know... im somewhat of an expert now at jdm fronts
Old Jun 9, 2004 | 05:34 PM
JaY-R's Avatar
does anyone have any pix they can post??? that'd be really helpful!
Old Jun 9, 2004 | 05:57 PM
JaY-R's Avatar
Default Re: (b18bb0y)
up for 'beach ready bodies' (refer to magazine =P)
Old Jun 9, 2004 | 06:05 PM
J_nicks's Avatar
From: Pomona city why you buullllshittin, CA [socal]
Old Jun 9, 2004 | 07:24 PM
K.F14's Avatar
Default Re: (hbLuvR yO!)
Hate to do this but give this guy a bump to help him out.
Old Jun 9, 2004 | 08:00 PM
JaY-R's Avatar
Default Re: (Winslow)
^^thanks man!
Old Jun 9, 2004 | 09:06 PM
R00teg's Avatar
I had to splice the line from my stock connector and attach it with a female adapter. The female adapter should fit into your stock JDM housing connectors. You can buy the female adaptor at any auto store(autozone, pepboy,....etc) Hope that'll help
Old Jun 9, 2004 | 09:11 PM
JDMx05's Avatar
those jdm headlights should of came with the harness, which would have totally made it easier on your wiring install.
Old Jun 9, 2004 | 09:21 PM
JaY-R's Avatar
Default Re: (JDMx05)
yeah... i know NOW.......
so i gotta find a female connector that fits into the jdm housing connector and splice my usdm wires into the female connector......?
Old Jun 9, 2004 | 09:25 PM
R00teg's Avatar
yep thats wut i did. The female adapters fitted tightly into the JDM connectors, which was good, which meant no worries about taping it so it will stay. AFter u figure out all the plugs for each lighting, I suggest taping the connectors with water proof tape so you won't get shortage cause of rain or so. Better to be safe then sorry. good luck
Now I just need someone to answer my damn spark plug question!!!!!!!
Old Jun 9, 2004 | 10:28 PM
JaY-R's Avatar
another question that popped up...
since the usdm hood latch is turned toward the engine.. and the jdm hood latch will be turned outwards... how did you install this?
how does the hood latch work when it's turned the other way? how can you open the hood?
and info about where to run the stock hood latch cable would be helpful as well.....
Old Jun 9, 2004 | 11:15 PM
Dc2 Powered's Avatar
i dont want to ***** ur trend but i was wondering for 4 door integras can a JDM front fit or do u have to weld or order a 4door jdm front? because i know the usdm front and rear are diff on teh 2/4 door models
Old Jun 9, 2004 | 11:22 PM
JaY-R's Avatar
Default Re: (Speedin Type R)
quit whoring MY thread man!
jp
Old Jun 10, 2004 | 02:53 AM
anngsr's Avatar
try on type R forum
Old Jun 10, 2004 | 07:03 AM
JaY-R's Avatar
Default Re: (anngsr)
thanks.. might try that
Old Jun 10, 2004 | 08:18 AM
itr_18's Avatar
just check which wires from car connects with wires from lamps. then buy connectors in store and "do-it-yourself". I did like that.
Old Jun 10, 2004 | 09:38 AM
marko_think's Avatar
lol
Old Jun 10, 2004 | 09:50 AM
NiceDc2r's Avatar
Default Re: JDM Conversion Questions (marko_think)
you can buy the connectors from password jdm or IPS (where i got mine).....ips will also send you the wireing diagram...if you do choose to hardwire the plug be sure to fill it with silicone to prevent corrosion
Old Jun 10, 2004 | 03:34 PM
JaY-R's Avatar
up for answers
