Uberdata on a Non-FI engine?
Old Jun 10, 2004 | 09:46 PM
WeaponR
Guest
Posts: n/a
Default Uberdata on a Non-FI engine?
Does anyone have uberdata installed on a non-vtec LS with basic mods? What were the gains, if any? Is it worth it?
Old Jun 11, 2004 | 12:36 AM
jDMJeRk's Avatar
Default Re: Uberdata on a Non-FI engine? (WeaponR)
jump in the uberdata forums and read up...i dont know link off hand
Old Jun 16, 2004 | 06:04 PM
WeaponR
Guest
Posts: n/a
Default Re: Uberdata on a Non-FI engine? (jdmjerk)
I've searched - its very tough to weed out the actual FI info from the NA info...
BUMP
Old Jun 16, 2004 | 06:29 PM
non-VTEC's Avatar
yes im running uberdata N/A. no "chip" would be worth on a basically stock LS. even if you have all the bolt ons. once you change your cams and/or injectors then it would be worth it.
works pretty good.......if you have the proper tuning tools (wideband o2 sensor, dyno, lots of time) it will deffinatly be worth it.......kinda hard to street tune the car without all of those things.
it pretty much does exactly what hondata does but it's free.
Old Jun 16, 2004 | 08:47 PM
tegmech's Avatar
Default Re: Uberdata on a Non-FI engine? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">yes im running uberdata N/A. no "chip" would be worth on a basically stock LS. even if you have all the bolt ons. once you change your cams and/or injectors then it would be worth it.
it pretty much does exactly what hondata does but it's free.</TD></TR></TABLE>
Cyphear put uberdata on Garbonzon311's gsr. Took out a bit of fuel and timing and changed vtec. Not sure exact amounts. However, the butt dyno told them it felt faster. There is a thread on the uberdata forum about na apps. Its pretty old so look back a bit and you will find it.
Old Jun 16, 2004 | 09:15 PM
Lastgsr's Avatar
if you get a good tune, it'd be the equivolent of getting a hondata tuned since they are the same thing bascially.
Old Jun 17, 2004 | 09:16 AM
tegmech's Avatar
Default Re: Uberdata on a Non-FI engine? (Lastgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lastgsr &raquo;</TD></TR><TR><TD CLASS="quote">if you get a good tune, it'd be the equivolent of getting a hondata tuned since they are the same thing bascially. </TD></TR></TABLE> actually, not really. You are using an experimental type program. One that a bunch of smart people came together and built themselves. Be prepared to have weird problems come along. The program has gotten better ten-fold in the past few months, but your still experimenting with it. Don't think that you won't run into issues along the way.
Also, getting a good tune is a whole other issue. There are very few people who tune uberdata commercially. Therefore you are probably going to have to learn how to tune yourself. This requires a whole lot of research. Including what your doing, why your doing it and what effects it will have. This will give you the best results, and not blow up your car.
Don't get me wrong, Uberdata is an awesome program. I helped(and were still messing with it) tune cyphears turbo ls with it. And its not that difficult to use. In fact its pretty easy. However, it can be easy to mess something up too. Good luck and have fun.
Al-sonic
Jan 16, 2008 09:19 AM
xXxDelSoulxXx
Nov 3, 2006 09:34 PM
bloodydc2
Mar 30, 2006 09:22 AM
viprcr1
Jun 28, 2003 05:57 PM
[HrZn]4life
Apr 17, 2003 09:56 AM
