ABS Sensor
Old Jun 10, 2004 | 06:36 AM
sQwiReL bOi
Guest
Posts: n/a
Default ABS Sensor
where is the ABS sensor located in the rear wheels? i broke mine off and i do not know wat to replace to get my ABS back. can i just replace the sensor? or do i have to change out whatever it is connected to? is it expensive to fix? worth it? thxs for the help. o ya... forgot to mention my car is a 97 gsr.
Old Jun 10, 2004 | 06:41 AM
boostinb20vtec's Avatar
the sensor is on the bottom portion of the hub...you have to take off a metal box that covers it and 2 screws out of the wire holder that are also on the hub section keeping the wire for the sensor from moving around and getting damaged. The sensor itself is replaceable, and it shouldn't be too expensive. You might have to solder it back on to the wire(don't know about how it is connected, but know where it is and how to take it off)
Old Jun 10, 2004 | 06:45 AM
sQwiReL bOi
Guest
Posts: n/a
so can i juss go to acura and purchase the sensor or like go to a junkyard and get 1? then solder it on?
Old Jun 10, 2004 | 06:56 AM
JimBlake's Avatar
Default Re: (sQwiReL bOi)
Most likely it comes with a foot or 2 of it's own wire. Then it unplugs from the harness somewhere. I don't know about the back, but the front wheel sensors unplug inside the engine compartment & the wire attaches to the knuckle & the fender. You might have to peel back some carpeting in the trunk to find the plug.
pilothelp
Jun 18, 2018 09:56 AM
Sikke68
Honda CR-V & Element
Nov 1, 2015 12:11 AM
DoRoJo
Sep 26, 2012 12:56 PM
maxogsr
May 26, 2005 11:09 AM
