wheel stud
Old Jun 10, 2004 | 06:28 PM
SPLNRSX's Avatar
Default wheel stud
Has anybody replace the wheel stud on a 95 Integra. Wondering if there is a way of installing a new one without having to replace the wheel bearing. Thanks.
Old Jun 10, 2004 | 06:44 PM
wreckedmyteg's Avatar
Default Re: wheel stud (rsxswa)
The bearing might or might not fall apart when you pull the hub. Have one ready just incase.
Old Jun 22, 2004 | 08:41 PM
CrazyModGSR's Avatar
Default Re: wheel stud (wreckedmyteg)
any more info or diagrams on this, i also need a knew wheel stud on my '94 teg
Old Jun 22, 2004 | 08:47 PM
Sack Master's Avatar
Default Re: wheel stud (CrazyModGSR)
I've done it on a civic without changing the bearing. When I did it on my teg I bought new bearings, hubs and studs so I didn't even try. But a civic would be exactly the same thing. Probably depends on what kind of shape its all in.
Old Jun 23, 2004 | 04:19 AM
JimBlake's Avatar
On my '95 front, there's not enough room to get the studs out & in without taking the hub out.
You press the hub (#5) out from the bearing (#4), which usually destroys the bearing.
Old Jun 23, 2004 | 07:04 AM
mrmonk's Avatar
Default Re: wheel stud (JimBlake)
iv'e always wondered what part # 17 does/is.
Old Jun 23, 2004 | 07:15 AM
JimBlake's Avatar
Default Re: wheel stud (mrmonk)
#17 is an anti-rattle spring, it's sides spring in against the pads. It also has a smooth surface for the pad to slide on. My Saabs & VWs don't have that, so after several years, the surface of the caliper bracket get worn. This way you can replace those #17s for cheaper than a caliper.
Old Jun 23, 2004 | 07:16 AM
Holds the brake pads in place
Old Jun 23, 2004 | 07:34 AM
CNSK's Avatar
My wheel stud broke all 3 and couldnt even drive my car. I took out the axle nut, pound the axle out from the hub. Then I used a socket that was a just bigger then then the axle socket, place it against the hub #5 and pound it out with a heavy hammer. Dont hit #4 bearing. After that just pound the **** out of wheel stud and add new ones.
I have always wonder, what if I just purchase a type R hub that has 5 lug hub with 5 lug rotors, add 5 lug wheels, and have me a type R 5 lug sort of suspension? Worth doing it?
waaBAAH
Honda Civic (2001 - 2005)
Jun 10, 2009 10:51 PM
z6hatchboy
Feb 6, 2009 06:31 PM
ryanstev
Dec 30, 2007 01:31 AM
Devo94ac
Jan 16, 2006 06:08 PM
nwdrifter
Sep 28, 2004 12:15 PM
