rear lower tie bar install question
i just bought a rear lower tie bar and i'm gonna put it in tomorrow but i've been given different advice on how to do it. since the tie bar bracket wont fit past the abs bracket, some people say to use 1 inch spacers and longer bolts but others say to remove the abs wire bracket and just zip tie the line to the tie bar. i dont want to use spacers because i'm not sure how strong they'll be. any ideas of the best way would be great! thanks
Re: rear lower tie bar install question (RIX982DRLS)
I've not seen where someone has used "spacers", but, quite often I see people just zip tying the ABS wire out of the way. Seems to work just fine.
Re: rear lower tie bar install question (ScreaminTeg)
the spacers idea i found in the archived search info, i guess i'll probably just wire tie em and try to make it look as least getto as possible. thanks for the reply.
RIX982DRLS
01-02-2005 04:43 PM
SLaMmEd GsR
07-31-2004 03:07 PM
