vibrations at ~80 mph?
Old Jun 10, 2004 | 06:18 PM
scartail's Avatar
Default vibrations at ~80 mph?
i recently got my shocks, springs, and tires done. i get vibrations in the steering wheel at about 80 MPH +/- like 2 MPH. Before I take it into the shop and ask, is there anything easy i can check before? It's a hassle with my schedule to take it by the shop.
Any help? There is a similar vibe at just under 18 MPH?
thanks.
Old Jun 10, 2004 | 06:26 PM
2000GSRT's Avatar
Default Re: vibrations at ~80 mph? (scartail)
were you wheels balanced?
Old Jun 10, 2004 | 06:40 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
check to see if the vibration stops when you take your foot off the gas pedal. If it does, then it is most definitely one or both of the inner CV joints.
Old Jun 10, 2004 | 10:09 PM
VsR785's Avatar
alignment & wheel balance?
Old Jun 15, 2004 | 03:05 PM
scartail's Avatar
Default Re: vibrations at ~80 mph? (VsR785)
yes i had all wheels balanced and an alignment. haven't notice about whether the vibe stops after i let go of the pedal. but it is consistent at ~80 mph. resonant frequency? i guess i have to make the effort and have tires rebalanced. Do you think it could be related to my camber kit.
thanks guys.
kham.
Old Jun 15, 2004 | 03:39 PM
Boofster's Avatar
Your tires are probably worn.
Old Jun 15, 2004 | 03:45 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: vibrations at ~80 mph? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">check to see if the vibration stops when you take your foot off the gas pedal. If it does, then it is most definitely one or both of the inner CV joints.</TD></TR></TABLE>
This happens often.
Check it just to be sure.
Old Jun 15, 2004 | 03:54 PM
dFreezy's Avatar
Default Re: vibrations at ~80 mph? (NightRider-gsR)
you shouldn't be going that fast, its against the law
Old Jun 15, 2004 | 05:14 PM
00b18b's Avatar
have your wheel bearings checked
Old Jun 17, 2004 | 07:43 AM
scartail's Avatar
wow.. there's a long list of items to check. I hope it is just the balancing.. i got the tires about 3 wks ago. but thanks a lot guys for all ur help.
Old Jun 17, 2004 | 07:55 AM
clin20's Avatar
my **** vibrates when i step on the brake, the steering wheel goes crazy, but i think its cause i need new brakes.
Old Jun 17, 2004 | 08:05 AM
mrmonk's Avatar
Default Re: vibrations at ~80 mph? (clin20)
or because your rotors ar warped.
Old Jun 17, 2004 | 08:22 AM
debogsr's Avatar
Default Re: vibrations at ~80 mph? (mrmonk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmonk &raquo;</TD></TR><TR><TD CLASS="quote">or because your rotors ar warped.</TD></TR></TABLE>
yep
Old Jun 17, 2004 | 08:41 AM
blacknbean's Avatar
hmm im having the same problem. I put new tires on and shox and springs and my steering wheel vibrates around 70-80, no more no less. i had the tires balanced twice and the shop said it was ok, so im going to go get a alignment and hopefully it will fix this..ill let u know
Old Jun 17, 2004 | 08:52 AM
Dawsonb17a's Avatar
New User
Default Re: vibrations at ~80 mph? (blacknbean)
Just drive 90mph, problem solved
Old Jun 17, 2004 | 08:56 AM
Tegblackman20's Avatar
u got a camber kit u might be getting some tire rub
Old Jun 17, 2004 | 09:03 AM
RNPoo7's Avatar
That just happened to me in my civic. It turned out that i have warped rotors. So i got them resurfaced.
Old Jun 17, 2004 | 11:29 AM
dc5r2002's Avatar
Default Re: (RNPoo7)
check to see if it does it when u are turning
Old Jun 21, 2004 | 10:44 AM
scartail's Avatar
Default Re: (Pulp Fiction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pulp Fiction &raquo;</TD></TR><TR><TD CLASS="quote">check to see if it does it when u are turning</TD></TR></TABLE>
YES!!! Slightly, very very small... You barely can feel it... at about 20 MPH as I am turning RIGHT! As I accelerate out of the turn it goes away.
What does this tell me?
Kham.
civicsracer
Dec 5, 2006 05:30 PM
92ehatch
22
Aug 5, 2005 03:03 PM
ITRIDER2001
Sep 21, 2004 04:37 PM
GapxGuy
22
Jun 12, 2004 03:16 PM
Mark
Oct 1, 2003 08:04 PM
