catch kan problems
Old Jun 8, 2004 | 10:44 PM
spreadm's Avatar
Default catch kan problems
hey ive gt a 91 B16A...just recently installed catch kan...ive hooked it up via the pcv valve...to the tank..then to were it originally went 2..itm....and ive noticed wif the kar runnin.. the hose becomes compressed a little....turn the kar off and its alrite...but as im driving.. say i take my foot of the gas pedal..u kan hear a faint whilsling noise....sum kind of pressure release dont no...
unsure...is my PCV valve bust..or hav i hooked it up wrong
cheers
Old Jun 9, 2004 | 06:25 AM
Xsi's Avatar
Xsi
Sounds like you have it hooked up right but you have cheap hose, there will be a fairly strong vacuum. The whistling noise must be a leak somewhere
Old Jun 9, 2004 | 06:26 AM
andrew dc's Avatar
Default Re: catch kan problems (spreadm)
pics would be nice, but basically it sounds like you have a vaccumm leak somewhere. Did you use hose clams, and the proper sized tubing?
check your work vs.
http://www.c-speedracing.com/h...n.php
For future reference, please make your post easier to read!
Thanks!
HTH
Old Jun 9, 2004 | 09:35 AM
Two_K Si's Avatar
Default Re: catch kan problems (andrew ef)
Do not use that cheap clear hose. Go get some fuel line hose from an autoparts store. Go over all hose connections to make sure they fit good.
Old Jun 10, 2004 | 12:05 PM
TodaSi's Avatar
Do not use steel wool to pack in the catch can....unless you want little pieces of steel working their way into your intake mainfold!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrew ef &raquo;</TD></TR><TR><TD CLASS="quote">pics would be nice, but basically it sounds like you have a vaccumm leak somewhere. Did you use hose clams, and the proper sized tubing?
check your work vs.
Thanks!
HTH</TD></TR></TABLE>
Hi Hater.
Dec 31, 2008 08:53 AM
mortificationrock
Jul 17, 2007 08:52 PM
lazilude909
May 26, 2007 10:35 AM
zirac50
May 21, 2007 10:44 PM
Coupe-R
Apr 13, 2006 01:52 AM
