lca bolt question
the bolts on my lca's were seized so i had to cut them out (both lca to strut bolts and one one of the outermost bolts). i bought 3 new bushings but i did not feel like spending $8 per bolt for the new bolts.
i went to aco hardware and picked up some GRADE 8 bolts that were almost the exact same size. so my questions is, will those bolts work or should i get the acura ones?
same thing happened to me a while ago, and I had to use some cheap *** bolt that wasn't even grade 8, and I rode on that all through winter and never had any problems...then again, I am redoing my suspension again now and will be going to the dealer to get those 8 dollar bolts to replace my old ones just for good measure this time. Dealer prices
. OEM quality
. OEM quality
Back when I first installed my stuff, I picked up some Grade 10.3 bolts in the exact size (a tad longer but same size and pitch) from Pep Boys and some washers to go with it. I ended up not using them because all my bolts came out w/o any problems.
aimbot
Aug 13, 2008 04:14 PM
ZipTieGUy
Feb 27, 2006 06:08 PM
