input on engine build for dc4
Old Apr 21, 2006 | 06:40 PM
sunnydeez's Avatar
Default input on engine build for dc4
alrite yall, i have a b16b block & oh yeah block code is p72.. with freshen' up kit
head is from b16a3 no p&p: using crower 403 cams w/rocket motorsports dual
valve spring & ti. retainers, skunk2 cam gears, stock mani., upgraded fuel sys.
(minus inj. & pump), jdm type r 4-1 header, stock like intake, minor upgraded ign.,
& last p73 ecu to call the shots. engine will be installed shortly & tuned w/ afc!
any suggestions on how i can increase my displacement, with it being a p72 block,
can i use a gsr crank & acheive 1.8 liters? bearing caps are stamped p72 as well,
so i assume the rods are the same as a gsr.... i wonder if the crank is the same,
too........
also this is my daily driver and i'm looking for the most reliable option
Old Apr 22, 2006 | 04:31 AM
sunnydeez's Avatar
Default Re: input on engine build for dc4 (sunnydeez)
no input, anyone
DENCIO
Jan 3, 2010 08:52 PM
PyroProblem
75
Oct 5, 2007 07:03 PM
2-logicl
Aug 10, 2005 08:07 AM
lemongreenhatch
10
Oct 21, 2004 03:24 PM
Vampyre
Apr 6, 2003 06:17 AM
