Overheating problem.
Old Apr 21, 2006 | 08:01 PM
Ithinkyourlost's Avatar
Default Overheating problem.
Ok, well me and a few mechs are confused on what is going on here. My fans do not click on, even when heater is all the way up. I just replaced the thermostat and the fan switch that is connected to the thermostat, i drained my coolent and replaced fluid, i squeezed out all the air bubbles. all connections seem to be fine. and after about 10 mins of driving it will overheat, idle is fine, doesnt ever overheat during an idle, and last time i drove, the temp guage would change from normal to high and back down rapibdly towards the end of the driving session, i unpluged the hose that connects to the intake to check and see if my head gasket is gone, i didnt see any white smoke what so ever, so please help me out a little here, give me some insight on what to do or look for. im stumped...
Old Apr 21, 2006 | 08:05 PM
Lan's Avatar
Lan
Default Re: Overheating problem. (Ithinkyourlost)
I know it sounds stupid but could you have installed the thermo is the correct position? Are both hoses filled with coolant? Maybe it is in upside down and is not opening properly.
Old Apr 21, 2006 | 08:08 PM
Im sure it is installed properly, i didnt install it, the dealership did, because i was getting body work done also because someone hit my rear bumper slightly and since im good friends with the dealership they went ahead and put my thermostat on for me, so im sure the dealership did it correct, i havent looked to hard, i just replaced the fan swtich that connects to it and i know thats on secure and right.
Old Apr 21, 2006 | 08:15 PM
Lan's Avatar
Lan
Default Re: (Ithinkyourlost)
Is there hot water in both lines??
Old Apr 21, 2006 | 08:19 PM
Default Re: (Lan)
yes in both lines it is hot.
Old Apr 22, 2006 | 12:39 PM
k well, ******* headgasket i think.
Old Apr 22, 2006 | 12:40 PM
Lan's Avatar
Lan
Ouch. That sucks. Leaking?
Old Apr 22, 2006 | 12:42 PM
Default Re: (Lan)
nah, thermostat isnt opening, even after replacing it. and everything is done right.
Old Apr 22, 2006 | 12:58 PM
integrid94's Avatar
you said your fans weren't kicking on at all?
sounds like a sensor or loose wires somewhere
are you blowing blue smoke out of the eshuats?
Old Apr 22, 2006 | 01:13 PM
Default Re: (integrid)
not really for the blue smoke, a little but that is only expected at vtec, not mention i need to replace PCV valve. yea, but the fans dont kick on fans are ok
Old Apr 22, 2006 | 01:15 PM
Lan's Avatar
Lan
Have you done a comp test after it is warmed up?
Old Apr 22, 2006 | 01:17 PM
Default Re: (Lan)
no i havent
Old Apr 22, 2006 | 01:20 PM
Lan's Avatar
Lan
If your headgasket is bad you compression numbers would be lower than normal. Try a test after it is warm but make sure you have coolant in there.
PaulMc
Feb 20, 2014 09:43 PM
mdoubleg
Nov 30, 2010 03:09 PM
LeArN2LiVe
Nov 22, 2008 12:08 PM
homeskillet
Dec 24, 2004 09:22 PM
akkord
Aug 15, 2004 06:47 PM
