fuel ?
Old Apr 22, 2006 | 08:56 PM
sik96teg's Avatar
Default fuel ?
Wuzzup guys i was wondering what u guys get on a tank of gas, what octane u run and maybe a list of mod to see the difference it makes.
im getting about 215 to the tank runin 91 octane or higher
engine is a type-r, full exhaust, aebs intake mani, bored out si tb by maxbore, cold air intake. Lets see ctr crank pulley b&m fuel pressure regulator. vafc, 8lbs flywheel stage 3 clutch. gs-r tranny wit type-r lsd. I think thats it. I started this jus to see the variations in fuel mileage cuz i think mines a lil low but im not to sure.
Old Apr 22, 2006 | 09:26 PM
Dartanian's Avatar
Default Re: fuel ? (sik96teg)
240-300 miles per tank depending on if I am doing my normal stop and go driving or highway driving. Averages out to 21-27 mpg. 91 octane only. See sig for setup. I am running 10 psi daily.
Old Apr 22, 2006 | 09:36 PM
sik96teg's Avatar
Default Re: fuel ? (Das Schmoo)
wow thats pretty good
Old Apr 23, 2006 | 06:36 AM
Dogginator's Avatar
Daisy... Daisy...
You must use the brakes alot. I have avearged about 27MPG over 65000 miles in my GSR. That includes winters, which kill gas mileage.
Old Apr 23, 2006 | 01:56 PM
sik96teg's Avatar
Default Re: fuel ? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">You must use the brakes alot. I have avearged about 27MPG over 65000 miles in my GSR. That includes winters, which kill gas mileage.</TD></TR></TABLE>
No not really i jus finished rebuilding it not to long ago everything seems to be set right my check engine light keeps going off every once in awhile its for tps dunno y thats set right too. Cant tune it cuz im stationed in the shittiest location ever so i gotta wait til june when i get out of the military to get it properly tuned. It runs good just shitty gas mileage
Old Apr 23, 2006 | 02:01 PM
Dogginator's Avatar
Daisy... Daisy...
What ECU are you running?
Old Apr 23, 2006 | 02:04 PM
sik96teg's Avatar
96 gsr
Old Apr 23, 2006 | 02:30 PM
Dogginator's Avatar
Daisy... Daisy...
Where is VTEC set on the VAFC? Do you think that the mixture could be rich from 4400 RPM to the VAFC VTEC crossover?
Also, are you taking many short trips where the engine barely warms?
Old Apr 24, 2006 | 12:35 PM
sik96teg's Avatar
i usually let it run for a bit before i go anywhere vtec is set at stock gsr setting at 4600rpms i havent done anything with the vafc because i cant dyno it and get it tuned here so i have to wait til i move for that besides i have never really used a vafc before. I think imma adjust the fpr a lil bit today to see if that helps. It runs perfect it backfires a lil every once in awhile when i let off of the gas but besides that its good.
CE1318
Honda Civic (2016 - Current)
27
Jun 3, 2018 04:17 PM
chiquito
Honda Civic (2006 - 2015)
13
Feb 19, 2008 08:12 AM
Fat Chick Magnet
27
Jan 13, 2008 10:05 PM
J337_UNIT
10
Feb 27, 2007 02:34 PM
rcurry14
Acura TSX
May 2, 2005 11:03 PM
