Headgaskets?
Old Apr 22, 2006 | 07:48 PM
EJ8 GSR-T's Avatar
Default Headgaskets?
Whats the difference between the b18a/b head gasket and the b18c1? ie whats the difference between the vtec one and the non vtec one?
Old Apr 22, 2006 | 07:56 PM
Sturat77's Avatar
Default Re: Headgaskets? (userdead626)
The location of the dowel pins is different and the VTEC gasket has a port for the oil flow to the head for the VTEC system.
Old Apr 22, 2006 | 08:18 PM
EJ8 GSR-T's Avatar
Default Re: Headgaskets? (Sturat77)
so could you use a nonvtec gasket on a vtec motor if you drilled out an oil hole?
Old Apr 22, 2006 | 08:19 PM
CleanLikeJdm's Avatar
Hype-R Stalker
doubtfully.
they're not much anyways, don't mess around with something like that.
Mr_Moos's Avatar
WHY BOTHER
A headgasket is very important wouldnt you want one for your car and not cheap out on it ???????????????????? seriously like $100 bucks tops.............
Old Apr 22, 2006 | 08:39 PM
EJ8 GSR-T's Avatar
Default Re: Headgaskets? (Mr_Moos)
not even 100$ its just a matter of cometic sending the imporper one
Old Apr 22, 2006 | 08:41 PM
Hype-R Stalker
Did you try getting it replaced/refunded?
Closer to 40-50 for an oem one then 100 though.
Old Apr 22, 2006 | 08:44 PM
EJ8 GSR-T's Avatar
Default Re: Headgaskets? (FlatBlackTeg)
its at a shop being worked on, i will just have them send it back and get a new one, i am just tired of delays for damn parts! and i figuerd if it were only a hole for oil they could just drill it, but better be safe than sorry
nanagsr
Feb 9, 2010 08:52 AM
black94lude
Nov 10, 2009 09:11 AM
miro_gt
Jan 26, 2009 10:55 AM
eg6madness
Oct 5, 2007 02:50 AM
stickeyfingaz
Dec 29, 2004 10:19 AM
