Alternator installation help
Old Apr 24, 2006 | 01:53 PM
integral94's Avatar
Default Alternator installation help
I am doing an engine swap, and to make things easier i removed the alternator from the engine. now i cannot fit the alternator back on to that part of the engine throught the top of the engine bay. should i go from the bottom? or am i SOL about this? do honda mechanics remove engines to replace alternators? any help would be appreciated, also links to step by step instructions would rule too!
thanks
Old Apr 24, 2006 | 02:01 PM
rgaray's Avatar
Have you tried going through the bottom?
Old Apr 24, 2006 | 02:05 PM
integral94's Avatar
I have and its not easy to do. i will try again tho.
Old Apr 24, 2006 | 02:30 PM
rgaray's Avatar
Yuo may also need to remove the mounts.
Old Apr 24, 2006 | 04:13 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Alternator installation help (integral94)
On some Honda/Acura, if you take off the wheel, and remove the wheelwell housing protector, you can access the alternator for easier removal/installation.
Old Apr 24, 2006 | 07:29 PM
integral94's Avatar
Default Re: Alternator installation help (tech8)
turns out it does fit from the bottom of the engine. thanks for your help though!
Old Apr 24, 2006 | 08:00 PM
debogsr's Avatar
Remove the drivers side axle. This is the easiest way to do it that i have found. Im assuming all of the brackets are on the block. The brackets might be harder to put on but yeah, take off the axle and your good to go!
EDIT- just saw you figured it out. Ill leave my post up so others can read. I know with a JRSC you gotta remove the axle, but i dont know if the alternator is in its normal location what you gotta do.
GavinJuice
Feb 21, 2009 07:49 AM
slamdunkcivic
Oct 18, 2003 09:21 AM
Shft@9GSR
Nov 23, 2002 08:05 PM
Frito1
Mar 30, 2002 06:24 PM
Street Racer
Mar 15, 2002 11:43 AM
