cooling problem
Old Apr 23, 2006 | 11:59 AM
JDM DERF's Avatar
Default cooling problem
i got a 91 integra with a built (mild) ls/vtec. I've never had problems with a water temp until now. I'm losing coolant from a small crack (or its just overflowing) in the reservoir tank. I keep having to fill the radiator (just bought new) before i drive it and it stills heats up! I replaced the temp. sensor, althought its used, but thats about all i've done. I just ordered a new coolant tank and new temp. switch and thermostat from spoon that i havent put in yet. What could be the problem??
p.s. i've had this motor for about a year and its never had this problem till now
Old Apr 23, 2006 | 01:19 PM
blkb18's Avatar
Default Re: cooling problem (DeityDA9)
Find someone with a pressure tester and pump up the system, make sure you pinch off the hose going to the reserve tank. This will rule out everything other than the reserve tank.
ARMED
Honda CR-V & Element
May 3, 2014 09:28 AM
EJ1_CRIS_909
Jul 18, 2012 10:03 PM
mn_babyboy
May 17, 2008 05:46 AM
twin rex's
Jan 27, 2006 09:10 AM
broke
Jun 10, 2002 01:49 PM
