Halfshaft replacement
I'm going to be replacing my halfsaft on my passenger side. Does someone have the repair manual for this? I've been lookin everywhere and searched for the past 2 hours and couldnt find anything to do with half-shaft or anything near that.
Here you go
https://honda-tech.com/zerothread?id=382416
Also, when you need to pop the balljoint loose, you might want to try this method if you're having a hard time
https://honda-tech.com/zerothread?id=887859
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95Integura »</TD></TR><TR><TD CLASS="quote">Is this for an integra? Cuz when you have to refill the tranny.....i cant find the hole on the top end.......</TD></TR></TABLE>
pull the speed sensor out and fill it threw there or remove the plug on the side of the tranny to fill it.
This was actually for an 92-95 Civic, but it's definitely the same for 90-01 Integras. I usually fill it through the regular old fill hole (it's the round bolt with the 3/8" drive notch in it), and then use some hose and a funnel to get the fluid in there.
Yeah, I found it. It took me awhile....was kinda confused of where it was suppose to be. But finnally finished the half-shaft considering that was the only part left to do. Thanks a bunch for your help.
vtec69
Sep 26, 2002 07:33 AM
