master cylinder help!!!!!
I need to replace the master cylinder on my DA, I was just wondering what has to be done to install one and how do you Bench Bled the MC? Thanks for any info.
Re: master cylinder help!!!!! (hangac1093)
Bench bleeding is easy. When I got my Autozone MC, it came with two short hoses that you stick into the ports of the MC. You fill it with brake fluid and loop the lines back up into the MC. Then you pump the MC with whatever tool you have around that will help you untill no more bubbles are seen.
Also, you are supposed to check the pushrod length, it is where the pushrod on the Booster meets the MC. Hopefully, the aftermarket or oem MC that you get won't need the adjustment done on the pushrod. You will know if your brakes drag all the time like someone has light pressure on the brake pedal.
Also, I gravity bleed my brakes, easy to do when flying solo.
mattbatson
10-23-2008 07:30 PM
bambam
15
06-20-2005 06:14 AM
