Checkin for codes
Old Apr 24, 2006 | 10:06 AM
jrzy2nR's Avatar
Default Checkin for codes
so the check engine light goes on....so i want to check the cel.....i read up on integra faq and it says to take the 2 wires and make it into one wit a paper clip and but the ends back into the connector.....well how the hell do u get the wires out in the first place those things are stuck in there.....
Old Apr 24, 2006 | 10:26 AM
jrzy2nR's Avatar
Default Re: Checkin for codes (jrzy2nR)
up need help here
Old Apr 24, 2006 | 10:29 AM
sleeperteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrzy2nR &raquo;</TD></TR><TR><TD CLASS="quote">so the check engine light goes on....so i want to check the cel.....i read up on integra faq and it says to take the 2 wires and make it into one wit a paper clip and but the ends back into the connector.....well how the hell do u get the wires out in the first place those things are stuck in there.....</TD></TR></TABLE>
just use a paper clip or a piece of wire to bridge the two together. stick the wire into the female plug where the wire plugs into the back. do this with the motor off and the keys in the ignition on the 2nd slot just before the car fires up. this should give you the codes. refer back to the FAQ for reading instructions and codes...
Old Apr 24, 2006 | 10:36 AM
LoseRPunKx182's Avatar
the point is to just jump that connector
Old Apr 24, 2006 | 10:56 AM
jrzy2nR's Avatar
Default Re: Checkin for codes (LoseRPunKx182)
so ur not suppose to take the wires out at all
sirEGhatch
Jun 1, 2009 11:30 AM
Al-sonic
Jan 9, 2007 08:29 PM
lsvtecna
Aug 6, 2006 01:13 PM
DOHC-ter AMIEL
Nov 8, 2004 04:58 AM
allmotorEG-SI
Jul 20, 2004 09:51 PM
