I JUST GOT A CAT-BACK EXHAUST INSTALLED AND NOW MY CHECK ENGINE LIGHT IS ON. IS IT TRUE THAT IF I UNPLUG MY ECU FOR 15 MINS IT WILL GO AWAY? IF NOT HOW DO I MAKE IT GO AWAY!????
it will go away, even you disconnect battery. but check the code if its o2 sensor, reset. but it might be something else. just to be safer.
Little Hercules
When you put your cat back on did you replace the cat with a test pipe? Is your ECU ODBII? If it is, did you plug both of your O2 sensors back in? If you did, check your codes, it's probably a 02 sensor. DO THIS BEFORE YOU CLEAR IT BY UN-HOOKING YOUR NEGITIVE BATTERY CABLE. It only takes 5 seconds for it to clear once you've un-hooked it. So make sure you check you code, something more serious could be wrong.
Little Hercules
here are all the codes
0 ECU
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolent Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
63 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
0 ECU
1 Oxygen Content
3 Map Sensor
5 Map Sensor
7 Throttle Angle
8 TDC Position
16 Fuel Injector
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
67 Catalyst System
you'll have to reset it often though. Mine comes back every few days but it'll randomly turn off. Nothing serious. I stopped resetting it, i don't notice a difference in performance with a CEL for cat.
Little Hercules
mine sometimes comes on about every 3 times i start my car
look for a blue button under the steering colum, its a reset button and your car is fine , it happened to me. just turn your car off and press it a couple times you should be fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type_R_Kills »</TD></TR><TR><TD CLASS="quote">look for a blue button under the steering colum, its a reset button and your car is fine , it happened to me. just turn your car off and press it a couple times you should be fine</TD></TR></TABLE>
sorry buddy thats for the maintinence required light.... and to the op that girl in your avatar is fione!!!!!
