lsv turbo build
Old Nov 9, 2009 | 06:37 AM
crxb16a90's Avatar
Default lsv turbo build
so i working getting all the parts together and doing research and making sure i doing it right.
well i read up that almost everyone put a knock sensor on the lsv motor. how important is it to use one on my setup.
stock bottom end, possible using forged piston. not sure.
8-12lbs max on boost, stock cr, i guess for lsv with b16a head be at 9.6
i have a running b16a so i be using most of the part of it.
right now my knock sensor is disable cuz my p28 ecu. i wasn't plan on getting p72 unless, knock sensor are must for the lsv. and also i heard that with forged internal does make the knock sensor goes off(stock honda one), even theres no knock. unless i reading it wrong.
anyway. so should i need it?
Old Nov 9, 2009 | 07:12 AM
YARO.'s Avatar
Default Re: lsv turbo build
Knock sensor is not important. They're not really any accurate most people disable them. PSI # is nothin without a turbo size and turbo setup. How much power are you looking for and what parts do you already have?
Boost_em1_
May 29, 2014 04:21 AM
h22lude317
May 22, 2009 08:58 PM
92ludeport
Jul 8, 2005 02:08 PM
Buzzbomb
Jun 20, 2005 03:51 PM
delslow94
Dec 26, 2002 12:52 PM
